Go to Post I just turned 51 and I'm still not sure what I want to be when I grow up! - Mike Betts [more]
Unread 09-09-2006, 23:26
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Pit design
166 has two crates that we ship to competitions.
One carries the robot, and another approximately the same size opens up and it has a tool chest, some shelves, a vice, a small work area, and a bunch of extra space to put any boxes that we might need. It also provides some space on top to put decorations and coats and stuff.
It's obviously more expensive to ship two crates, though.
One
Two You can kind of see the the openness of it and a very glorious picture of our robot at no extra charge.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 09-09-2006, 23:44
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
Re: Pit design
three things ive definately learned
(might be things you thought of already, but its just my 2 cents)
1. easy to trasport, something that breaks/folds in to pieces but not too many or else that will be not good
2. good support for the top if you decide to create a "roof"
3.easy to assemble
Product Designer, Mechanical Engineer
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce / Team 4 Element Alumni / Former 1646 Precision Guessworks Mentor
Unread 09-09-2006, 23:51
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Pit design
Okay after 5 years of experience, I think we've finally got a simple Pit design and system down. 10'x10' frame made of PVC (we painted it Green) with no segments larger than 45" for fitting in the crate with a robot. Plastic shelves hold many of small bins of fasteners and spare parts (heaviest ones on the bottom of course). Rolling Tool chest on opposite side of pit. And the plastic shipping bins you get each year are used to pack the tools and parts can then be stacked on top of each other and place a table cloth over and whalla you have a couple of nice end tables to put out buttons and handouts. We also had a projector running video highlights from the past competition. I've seen some way cool pit areas, way cooler than this, but this was cheap (excluding the projector!), easy to setup and transport, and made the area look nice and still functional.Here's a pic
Unread 14-09-2006, 09:18
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Re: Pit design
I have put a bunch of photos of good pit designs onto our team photo-sharing web site at http://rollingthunder.smugmug.com/gallery/1414921 from the 2006 Atlanat world championships. In our 2nd year, we created a really cool pit which won us the imagery award at the Boston regional (along with our team camouflage uniforms, etc). See some pics here: http://rollingthunder.smugmug.com/photos/67064497-S.jpg
Some thoughts:
1) Portability and easy-setup is critical, especially if you're going to Atlanta championships via public transportation.
2) Abide by the rules as defined by FIRST and expect the rules to improve year-after-year. FIRST now mandates a maximum height of the pit. There is now a "typical" 10'x10' maximum footprint for a pit, but not all regionals have this (yet).
3) Safety is the next consideration. Pits should be stable, and some regionals get a bit fussier about flameproofed fabrics, spotlights in the pits, power strips, etc. Your team needs to have EASY egress from the pit with the robot on the cart (height clearance?). Therefore, side curtains, etc are a real pain in the #$%^&.
4) I strongly advocate NOT putting up side walls nor a "roof" since a) it blocks out a lot of light and b) is somewaht unfriendly to your teams next-door.
5) Many teams use PVC pipe (electrical schedule 80 or plumbing sched. 40) which is OK, but only in shorter lengths. Consider cutting sections into easy-to-handle lengths and then use a "coupling" and a bungee cord at each break such that the pit poles can be dismantled like a mountaineering tent. Go check out camping stores to see tent frameworks.
6) Be sure that your pit does NOT stick out into the aisle. Think creatively about making shelves, organizers, out of fabric with pockets instead of rigid materials in order to ship them. Here's an example of a collapsable shelf unit: http://rollingthunder.smugmug.com/photos/67064483-S.jpg
7) Additional thoughts:
-- Make pit components fit into the robot crate (along the side; securely-mounted with Bungee cords) as long as it doesn't make the crate weigh too much
-- Re-use the doors of your robot crate as folding tables. There are leg kits available on the Internet which can be mounted to the inside face of your robot crate doors. be sure they're stiffened to use as tables, not just 1/2" plywood....
-- Figure out a way so that your tool boxes become "bases" for table, etc. Same holds true for those big plastic tubs.
-- make sure that you have a way to show-off your team's literature out front, a dispenser/bin for button hand-outs, display stuff for judges walking by. Just go to a real trade show and benchmark what they do...have fun.
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 14-09-2006, 09:56
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
Re: Pit design
I'm currently in the middle of working with our mentors and redesigning HOT's pit. It won't be changing too much though.
Thanks for all the pic's everyone! Gives ideas
I'm proud to be a...
Unread 17-09-2006, 21:45
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: Pit design
This year's MORT cart had two (IMO) important upgrades over the previous version.
1) Magnetic tool/hardware trays. Cheap and incredibly useful, putting a couple of these on a cart/table give you a secure and easy to find place to store hardware and tools so that they can't roll away or fall. (Like This or this .
2) Slotted cart-top to hold the robot. Our robot frame fitted securely into two channels on our extruded aluminum cart. No risk of rolling and also about a foot above the work surface of the cart allowing more space for tools, etc. underneath.
Our pit isn't all that sophisticated. Keep extras of everything and don't forget the zipties. (both learned the hard way) We keep our spare hardware, serial cables, electrical parts, and other small parts in plastic organizer boxes. (A bit like fishing tackle boxes.)
It's good to have some form of tool organization, but ours is just a husky tool chest with drawers. It works, but I've seen other teams with entire walls set up with hooks for tools and countless other organization systems, many of which are probably more effective than our toolchest.
Our batteries and chargers are kept in a wheeled cabinet filled with power strips that is plugged into the pit power supply and with a shutoff switch. All chargers (robot, drill, backup, laptop on occasion) are kept out of the way in this manner. It also gives us a lot of free outlets for tools.
Don't forget to tape down extension cords. Loose cords are a major hazard with so many people moving so fast.
Overall, I think that your pit crews direction and training is more important than your organizational system. You can be as organized as you want, but it will all fall apart if nothing gets put away. Make sure everyone knows where everything is and how it should be put back. Pick a couple promising freshmen and make them pit monkeys. They're in charge of the "get me this tool" and when the robot goes to queue, one of them stays behind to man the pit and clean up for after the match, when it'll get crazy again. The freshmen will be honored to have the job (I know I was) and it'll keep your pit clean and organized.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
A clean pit is a happy pit. Kyle Love Chit-Chat 8 27-10-2007 13:59
[Official 2007 Game Design] OK, so YOU design the 2007 game... dlavery FRC Game Design 44 17-12-2006 17:05
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
pit arrangments DAN THE MAN General Forum 2 27-02-2005 02:49
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
