Go to Post A lot of the time in FIRST it's not what you have when you enter the program, but what you gain from being in it. - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 10-09-2006, 08:20
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: USB Joystick adapter is here!
Originally Posted by Greg Marra
Actually, thanks to a standard (USB human interface device class) most any controlling device should work with the USB Chicklet. The only problem would be how the chicklet chooses to map all of the possible channels in an HID device to it's limited number of channels, but the standard does exist. "Proprietary drivers" are often required for unusual functions that require an extension of the standard, and those 'extras' wouldn't work with the chicklet.
You are correct. The Chicklet will support ANY HID device. The only limitation is what we (CTRE) introduce. You are also correct in your statement about mapping the inputs. However we have solved this issue by implementing functionality that allows the USER to select the configuration of the game pad and x-box controller. The logitech game pad, for example. The user will be able to select from one of two modes.
Mode 1: 4 digital buttons selectable by the user and 4 analog axis(x,y & x,y)
Mode 2: 12 digital channels and 2 analog axis (y,y)
Also, any device that is not yet supported can be added.
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
USB-Serial adapter Bill_Hancoc Chit-Chat 4 03-01-2006 07:18
USB to Serial adapter John Gutmann Programming 7 09-05-2005 01:34
BAFO USB to 9 Pin Adapter Skiguy523 Programming 2 29-01-2005 01:49
