Go to Post The thought of destroying any robot is just......depressing :( - Richard McClellan [more]
Unread 11-09-2006, 22:32
David Carter's Avatar
David Carter David Carter is offline
FIRST
AKA: DC
None #0842 (Falcons Robtics)
David Carter is on a distinguished road
Send a message via AIM to David Carter Send a message via MSN to David Carter Send a message via Yahoo to David Carter
IFI Analog Code
When i insert the IFI analog code it wont build right! Any Suggestions?
(Get_Analog_Value(rc_ana_in01)
Unread 11-09-2006, 22:39
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: IFI Analog Code
Could you post the complete block of code as well as the build error?
Unread 12-09-2006, 00:52
FIRST
AKA: DC
Re: IFI Analog Code
It's ok i got it i for got to take out the define_ana_ bla bla bla crap i for got to take it out
Unread 12-09-2006, 09:28
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: IFI Analog Code
Just for your own knowledge, if you're going to respond to your own thread to tell us that you solved your problem, you should try to give as much details about what you did as you can. Someone may have the same problem that you do and may benefit from your solution.
Plus, your post may be the most unintelligible thing that I've read in a while. Part of being an engineer/scientist (or just about any other profession) is being able to express yourself clearly. Don't take that as a slam, but as constructive criticism.
Unread 12-09-2006, 11:54
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: IFI Analog Code
Dave, are you meaning to say UNintelligible?
If so, I agree, as I couldn't understand David's post either.
BEN
Originally Posted by Dave Scheck
Plus, your post may be the most intelligible thing that I've read in a while. Part of being an engineer/scientist (or just about any other profession) is being able to express yourself clearly. Don't take that as a slam, but as constructive criticism.
Unread 12-09-2006, 14:20
Re: IFI Analog Code
oops... yeah, I meant unintelligible
Unread 12-09-2006, 15:35
FIRST
AKA: DC
Re: IFI Analog Code
Ok then!
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
New IFI Default/User and Master Code Alex698 Programming 6 28-02-2006 23:04
problem loading code with ifi loader psych0gambit Programming 7 25-02-2005 20:43
Analog in on OI: Heads Up! Astronouth7303 Programming 5 05-02-2004 17:55
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
