Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
Go Back   Chief Delphi > Other > VEX
Unread 12-09-2006, 21:48
d4x20r d4x20r is offline
d4x20r is an unknown quantity at this point
Vex Robotics Tank
This is a tank using Vex Robotics parts. I built this back in March, I think. I never finished it. Wiring and programming are still required. I bought $800 worth of Vex parts and all I've done with this stuff is build the tank and it's been sitting ever since. I thought I'd get back into it, but I started a different hobby instead. And now I need money to support that, so if you're interested in buying this you can PM me about it.
Features of the tank include:
Two individually controlled "guns" (shoots rubber bands).
Each "gun" has two limit switches. One to stop the movement when it reaches bottom, one for the top.
Each tank tread has its own motor for real tank motion controls.
Programable light sensor so that tank shoots when it detects a bright light (have somebody point a flash light at it).
Ultrasonic range finder.
Rear bumper switch.
6-Cell 1500mAh rechargable battery.
Re: Vex Robotics Tank
Unread 13-09-2006, 00:48
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Also try posting this in the section of this forum called CD-Swap this is where people post what they are looking to buy, and trying to sell. Its just another way to get your product out there...Good-Luck!
Unread 23-09-2006, 08:50
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
That's so awesome!!!
How long did it take you to build it? You obviously put in a ton of time. Kudos to you, lots of kudos.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 25-09-2006, 16:59
1337vex0r 1337vex0r is offline
1337vex0r is an unknown quantity at this point
that thing is awesome! kudos to you!
Unread 26-09-2006, 00:35
Thanks. I really didn't put much time into it. I didn't even know what I was building when I started. It was the first (and only) "robot" I attempted building. I put the tank treads on a chassis and built up from there. It kinda just went together that way...
Unread 03-10-2006, 10:03
Please do not PM or email me about selling this stuff anymore because I sold it this morning. Thanks.
Vex Tank Tread Screw Problems Jake Lewis FIRST Tech Challenge 4 27-06-2006 18:23
vex robotics capof541 FIRST Tech Challenge 3 17-05-2005 18:00
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
