Go to Post ..the way we see it FIRST isn't about winning a robot contest, its about trying your best to complete a really really hard task in a really really short amount of time. - Stuart [more]
Unread 18-09-2006, 14:48
Billfred's Avatar
Billfred Billfred is offline
Re: Improving the KOP Skyway wheels
Originally Posted by M. Krass
How were they connected to the drive?
I can't speak for 1902 (or anybody, for that matter), but it seems that the standard way of doing it is to use the plastic hubs that come in the kit and grab the spokes, which are then bolted together on both sides of the wheel. This allows for teams to use just about any FIRST-targeted sprocket (either KOP, IFI, or AM).
Unread 18-09-2006, 15:08
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Our breakage was a result of the wheels coming off the ground and slamming back down. It seemed like after a few hot/cold cycles from shipping they became brittle. Until 2005 we hadn't had as big an issue. This caused us to look at alternatives and we used the IFI last year which were great after me made a few changes to them. For 2007, well that's TBD. We plan on comparing IFI v2, Colson, and something I'm not sure even we can make work.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 18-09-2006, 21:07
Gdeaver Gdeaver is offline
FRC #1640
The broken wheel referenced in the picture appears to have been modified. Our team has used the KOP wheels unmodified in a 4 powered wheel configuration and never had a problem. Maybe it's the modifications that are causing the problems.
Hubs for the 8" skyway wheels rswsmay Kit & Additional Hardware 3 12-01-2005 15:57
How do you drive the KOP 6" wheels? Alex Cormier Technical Discussion 7 04-11-2004 17:14
has anyone ordered the wheelchair wheels outside of skyway? archiver 2001 0 23-06-2002 23:17
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
Skyway Wheels fs_2002 Rules/Strategy 1 11-01-2002 15:27
