Go to Post "Rookie" just means you are new to the game, not that your team isn't as skilled as many already in the competition. - Bill Moore [more]
Unread 18-09-2006, 16:12
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Light Filter
In the Hangin-A-Round game manual it states that you make use any material used specifically for the light sensor as a filter. How would i go about filtering the colors.
-Dustin Benedict
Unread 18-09-2006, 20:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Light Filter
Let's say you want to filter OUT the color yellow. You place a Yellow colored piece of something transparent over the thing doing the looking, and the yellow material makes all things that are yellow appear to be the same as things that are white.
Try it. Find something colored and transparent, and look at the world through it. Green is especially weird outside.
You may note that the "filter" doesn't exactly cancel out the color, you can tell a difference between the colored item and a white item. That is because the color of your filter is not exactly correct.
People in the photography world use colored plastic sheets, thin like an overhead transparency, available in literally thousands of different colors, for exactly this purpose. Go to a high-end photography store - not a chain store - and someone will surely send you in the right direction.
Hope this helps
Don
Unread 19-09-2006, 22:40
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: Light Filter
Some stage lighting companies use to sell sample books of what are known as lighting gels. They were about business card sized samples of gel filters used on theatrical lighting. Hopefully, those sample books are still available. You'd have a lifetime supply of filter material for a vex light sensor, and in every color imaginable.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
FRC analog input RC filter values Gdeaver Control System 2 01-01-2006 22:03
Gyro Filter MikeDubreuil Electrical 7 04-02-2003 17:26
Now with a competition filter!!! archiver 2001 0 24-06-2002 02:10
Broken Light archiver 2001 1 24-06-2002 01:01
