Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 20-09-2006, 21:47
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Properties of MDF...
Wow, Thank you.
I am actually making a Subwoofer box (or two), and needed to compare the properties of MDF and lexan, to see if I could substitute one for the other. After doing so, I went ahead and bought a 4x8 sheet of MDF to construct the box with.
I have another quick question...
Having to fit in the trunk of my car, the box I am making is a very odd shape, and therefore I am having trouble laying out the patterns for the individual side panels of the box on a single 4x8 sheet of wood. Does anyone know of a program or another easy way to do this, aside from making cardboard templates? Something that makes sheetmetal foldouts might help, but I am having trouble finding a program like that...
Any help is appreciated, and thank you A LOT for all that I have recieved so far
-Cody C
Unread 21-09-2006, 00:20
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Urea-formaldehyde resin along with the very fine dust particles make MDF hard on your lungs. Wear respiratory protection when cutting it.
Unread 05-11-2006, 21:59
Andrew Blair's Avatar
FRC #0306 (CRT)
As an unrelated but interesting sidenote, MDF's porosity means that you can utilize it on a vaccuum table.
No need to set foam in channels or make jigs for oddly shaped pieces- you can simply lay the board down on the table and if your piece is sufficiently smooth and not porous (Corian works great- i'd imagine lexan and aluminum work too), your piece will hold right down. And you can cut into it, typically without losing your piece.
We did this with our wood shop's router. Works great.
-Sir Francis Bacon
-Albert Einstein
Mass properties in Inventor telkanuru Inventor 2 26-02-2004 21:59
Bridge Mass Properties archiver 2001 6 23-06-2002 23:02
