Go to Post One wondered why they couldn't practice in the gym that day - because the robotics team had it reserved was the answer. "Oh, we have a robotics team?" Sigh. This is a team with a low number. They've been around for at least a dozen years. There's still a lot more culture-changing to do. - GaryVoshol [more]
Go Back   Chief Delphi > Other > VEX
Unread 20-09-2006, 11:51
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Using DC motors
Hi,
I have another question, but this time rather more complicated.
I have 2 DC motors which I want to connect to the VEX controller. Because they are DC I can't connect them to the PWM port.
My Electronics teacher has suggested me to build 2 small electric circuits using L293 chips that control motors, connect each chip to an amplifier and connect all that to a digital output.
If I do all that, I will we able to simulate a PWM signal, using the digital outputs and a timer.
My problem is that I don't know how to write the code for the PWM control in a way that it will be running simultaneously with the general code of the program.
Can someone help me?
I hope I've made myself clear,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 20-09-2006, 12:59
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Using DC motors
This has a pretty good write up on building the circuit plus it gives you some code to make it all work. It is not discussed at this site but the chip does have a pwm controlled pin for controlling speed. There are many sites that will give similar results if you search using L293.
Here is another site.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 20-09-2006, 13:03
Billfred's Avatar
Billfred Billfred is online now
Re: Using DC motors
Originally Posted by Guy_E
Hi,
Guy
What kind of DC motors are you working with? If they're 12V (or 24, or 36, or 48), you should be able to interface a Victor directly with the Vex controller's PWM outputs (just use a Y-cable to get the appropriate male-to-male connection). Someone who's more familiar with the Victors can tell you if and how well they handle smaller voltages.
It's less legwork, which may be a good or a bad thing for your project, but there is something to be said for keeping it simple. Hope this helps!
Unread 20-09-2006, 13:11
FRC #1574 (MisCar)
Re: Using DC motors
My problem is not with the electrical part.
What I want to know is how to intergrate it with the general vex code. Just to mention, im programming using MPLAB.
Visit our website:
www.miscar1574.com
Unread 20-09-2006, 15:22
FRC #1574 (MisCar)
Re: Using DC motors
I wish I could use a victor, but my motors are 6-8V DC .
Visit our website:
www.miscar1574.com
Unread 20-09-2006, 15:36
in between teams
AKA: Luke Van Oort
Re: Using DC motors
The Victor 884 is rated for 6-15V.
Team 1219: 2009 - Mentor
Unread 21-09-2006, 05:28
FRC #1574 (MisCar)
Re: Using DC motors
I think a victor is a little too big for my robot.
Visit our website:
www.miscar1574.com
Unread 21-09-2006, 12:58
Culvan Van Li's Avatar
Culvan Van Li Culvan Van Li is offline
Jack-Of-All-Trades
AKA: Andy
FRC #1939 (Kuh-Nig-Its)
Culvan Van Li is on a distinguished road
Re: Using DC motors
Another thing to be aware of is the difference in PWM (pulse width modulated) signals. The VEX motor ports output a PWM signal that has a 1-2ms pulse every 18ms (11% - 22% duty cycle). This is the same style that is used for remote control servos. The Victor88X controllers are designed to take this type of signal.
If you design your own circuit using a L293 (or similar part) you will probably need to generate PWM signals that cover the entire sepectrum of duty cycles (0% to 100%) because you will probably be driving a transistor to drive the motor directly.
I'd also recommend you look into the HB-25 from Parallax. It functions like the Victor controllers but costs about 1/3 as much. It's a little bit smaller too. I'm currently using these with my VEX controller for cordless drills.
Andy
using non-vex motors MarkH Motors 3 23-04-2006 21:04
using more motors Aren_Hill Motors 6 13-02-2005 17:44
using more motors Aren_Hill Technical Discussion 2 13-02-2005 15:52
Using 6 motors in a drive system? FIRST JerseyKid Motors 7 12-01-2005 23:49
