Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 22-09-2006, 19:32
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Build your own Arc Welder!
This got featured on hackaday.com yesterday.
http://www.hackaday.com/2006/09/21/m...en-arc-welder/
Unread 23-09-2006, 09:45
For those of you thinking of trying this at home, be sure to read the entire article. The use of the microwave oven transformers requires rewinding each one. A microwave uses at least 4000 volts to make the magnetron tube function and that voltage may still lurk inside, stored in the capacitor(s). Since a welder uses low voltage, each transformer will need extensive modification and most of the ovens you will find on the trash heap in this country are wired for 120 volts.
How-To: Build your own CNC machine David Kelly General Forum 1 29-06-2006 23:34
How many of you build your own field? Jessica Boucher General Forum 43 07-03-2006 21:15
Your Own Team Siggies Cujo General Forum 8 26-02-2005 16:01
Build Your Own Robot Kit Rich Wong Robotics Education and Curriculum 2 30-12-2002 20:50
Making your own gearbox? ChaosMonkey Motors 15 25-05-2002 11:07
