Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 23-09-2006, 23:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Team 306's (maybe) roller system.
3000 rpm is awfully fast. That means you're actually gearing the big CIM up. I'm not so sure you want to do this, as you run the risk of either stalling the rollers, or depending on the hopper on your robot, shooting the balls right out of the top.
Secondly, adding that second roller creates a choke point. Your first roller may be running at 3000 rpm, but the second roller is running at a mere fraction of that. The speed of the second roller is the limiting factor, and you'll never be able to utilize the higher rpm front roller to pick up balls faster if they all jam when they hit the slow roller.
Our pickup was somewhere around ~1000 rpm, and we could drive full speed into a line of balls and pick up all of them without having them feed too slowly into the robot, and jam.
2001-2004: Team 100
2006-Present: Team 254
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
pic: 1902's intake roller Dan Richardson Robot Showcase 7 14-02-2006 20:59
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: rookie team 1481's 6 cylinder pneumatic system. (very organized isn't it...) CD47-Bot Robot Showcase 3 02-02-2004 23:19
Animatrix (maybe spoilers, maybe no.) Frank(Aflak) Chit-Chat 8 03-06-2003 22:14
