Go to Post The FIRST program is different. It has a different purpose. It isn't superficial, it's results are long term and lasting. I hope that FIRST is still on message. - JohnBoucher [more]
Unread 23-09-2006, 12:00
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: FIRST air cannon robots PVC??
Don't use PVC unless you absolutely have to.
If you do use PVC, wrap it in duct tape so that if it ruptures, the fragments won't kill you. One member of our team had a near miss when a PVC tank blew up. He made it out with a nasty scar on his forehead, but he could have been much less fortunate.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 23-09-2006, 12:37
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by Andrew Schuetze
This was indeed prototype 0.1. I used 8 KOP tanks in four parrallel circuits. I.e. two tanks in series feeding into a manifold with four inlets. The manifold was all 0.5" black pipe tees. I then used couplings to enlarge the opening to the 1.0" diameter for the sprinkler value. Not nearly enough air flow was generated to launch the tee shirt out of the 3.0" diameter barrel.
I'm looking at an alternative now, if that method didn't work for you I really can't see it working any differently for us especially with the same barrel.
Unread 23-09-2006, 12:42
Originally Posted by Billfred
I get the basic concept, but what would work for the pin? It'd have to be something strong enough to handle the force of the cylinder, yet also be able to be yanked out of place (or so I think).
it could be something you pull like a trigger on a gun. It doent have to be pulled out of the way quickly, because the cylinder is already pressurized behind the stop.
Also, I think the largest cylinders you can get from the supply list has a 2 foot piston. That should be big enough to shoot just about anything!
Unread 23-09-2006, 19:36
Gdeaver Gdeaver is offline
FRC #1640
A Sabot casing for the tee shirts would cut down on the volume of air and flow rate needs. Properly designed the sabot casing would only go a couple feet. Sabots need a very smooth bore. Seam to remember a few casing designs for water balloons online. Starching and a tight roll will keep the shirt in a good projectile form.
Unread 24-09-2006, 02:52
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Our team is working on a similar project. We considered the use of PVC, but decided to use a tank instead. Our local Walmart sells a 7 gal 120 psi tank for 20 dollars; the decision to use the air tank is about as expensive as PVC tanks would be for a similar volume and has left everyone on the team feeling safer. If you do use PVC consider netting around the PVC similar to that used around pressurized laboratory glassware.
Unread 25-09-2006, 19:15
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
not that i support nor encourage the use of pvc for pressure tanks i have heard however of wrapping the pvc tanks in many layers of duct tape incase of a blowout it prevents shard from injuring someone. just a thought.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 25-09-2006, 22:20
Im having a hard time with some of the ideas being presented of ways to make a PVC tank less dangerous by wrapping it with nets or tape or wire
that seems like a seat of the pants kinda thing to do. You would have to test the end product many times to see whether it contained all the little pieces, or whether it made things worse. You would have to repeatedly blow up PVC tanks in a controlled environment, and find a way to measure the energy of the resulting fragments. (Sound like a job for the MythBusters!)
And dont forget the concussion if it blows in a small area. It doesnt take much of a bang to permanently destroy your hearing.
This reminds me of people who put an X of tape across their windows or sheets of plywood, when a cat 5 hurricane is coming. When they return their house is completely gone!
Unread 26-09-2006, 18:58
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
If an type of pressurized system blows in close proximity to your ears....ouch
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 27-09-2006, 01:51
dtengineering's Avatar
AKA: Jason Brett
We have had some luck with building a PVC water balloon cannon. I only let the students take it up to about 75 psi until well after they had graduated and were "responsible" for their own safety. We took it up to about 90-100 psi for a couple of shots, then destroyed it before fatigue (or cockiness) could set in. Your mileage may vary, compressed air is inherently dangerous and we took appropriate safety precautions.
The book "Backyard Ballistics" describes a pneumatic petard that was the basis for our design. I do recommend a video on youtube, however, http://www.youtube.com/watch?v=_zxlFoZhOC4 to illustrate both the majesty and power of compressed air.
Jason
Unread 27-09-2006, 16:38
Back in the Game
AKA: Ed Venator
FRC #2399
I'm definitely not advocating PVC tanks. I'm just saying that if you're going to be an idiot, please be slightly less of an idiot.
MORT 11
HB 2399
Unread 01-10-2006, 21:26
The Arizona Mentor
AKA: Andrew
A question on the irrigation valve; we've gotten it to open by applying power on the relay forward, do you need to apply reverse power to close it or just turn off the forward part?
Unread 01-10-2006, 21:29
Andrew Blair's Avatar
FRC #0306 (CRT)
The valve will close when power is removed. The solenoid is only used to open the valve- the return spring closes it.
-Sir Francis Bacon
-Albert Einstein
Unread 01-10-2006, 22:26
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
When I get a bit more time, I'll add links to the various threads on C.D. on this topic.
My question is how / where does one get a definitive answer as to the pneumatic pressure rating of schedule 40 PVC? I was intrigued by the team fusion air canon last year and then decided to add one to our 2005 robot this August. I'll post a picture of the prototype mounted on my classroom workbench. It works okay. Based upon three weeks of development, what I perceive to be limiting the performance is the restriction of air flow from the storage tank via the 0.5 inch fitting. Everything else is the same 1" diameter as the sprinkler valve and then expands to the 3" diameter at the back of the muzzle.
I've seen about three cannon systems which are using PVC pipe as the pressurized air storage system here on C.D. People have commented that PVC pressure ratings are for water systems and in fact the fine print at the store indicates use for water only.
My fear is that a bump into a doorway or drop on the floor may start a crack in the PVC pipe and eventual lead to catastrophic failure.
How do I know if I am being overly cautious or just being prudent?
APS
Toltech prototype
We use 60 PSI and we can shoot quite far, so we don't use any crazy pressures like many people are assuming. At most we have put 90PSI in when we were trying to shoot a croquet ball across the football field, but no one was in the stands or the field. Also, we use some type of PVC sleave in the middle of the cannont to prevent it from expanding too much. Just a suggestion, if you get a sprinkler valve that is rated at 24 volts, don't run it in series with a spike. The spike leaks enough current to keep the valve on after releasing your firing button, and it will not work right with only 12 volts. We use 3 9V batteries in series going through a relay connected to a spike and it works well for us.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 26-10-2006, 17:24
Kaizer007's Avatar
Kaizer007 Kaizer007 is offline
Hyped up on half and half, Mentor
AKA: Daniel
FRC #0498 (Cobra Commanders)
Kaizer007 is a jewel in the roughKaizer007 is a jewel in the roughKaizer007 is a jewel in the rough
Send a message via AIM to Kaizer007
We have successfully completed building our robotic air cannon. (We converted our 2005 robot) Donut might get some pictures uploaded on here later. We used a blue seven gallon air tank for storage. I'll get the specs to you all later and how we built it.
Unread 27-10-2006, 18:10
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We are using a 24 Volt Sprinkler valve, and we thought about how to hook it up to the spikes or a separate battery source like the 3 9V option. But then we tried making it work with just the 12 Volts - and walla... no problem. we've been running this way for the past year. Also polarity (forward or reverse) doesn't matter on most these sprinkler valve solenoids as most of them are meant for 24 V AC. We've switched polarity on ours and had the same results.
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
Too Powerful cannon? I Eat Robots829 Chit-Chat 15 03-02-2006 00:19
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
