Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 25-09-2006, 10:20
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
pic: Impressive rookies
Unread 25-09-2006, 10:22
Billfred's Avatar
Billfred Billfred is online now
Re: pic: Impressive rookies
Can someone fill us in on some more details? It looks like a Triplets drive base modified to be a dumper. (Matter of fact, it looks a lot like a shooterless Triplet.)
Unread 25-09-2006, 10:41
Hafize's Avatar
Hafize Hafize is offline
FRC #1305 (Near North Student Robotics Initiative)
Hafize is a glorious beacon of lightHafize is a glorious beacon of lightHafize is a glorious beacon of lightHafize is a glorious beacon of lightHafize is a glorious beacon of light
Send a message via MSN to Hafize
That robot is the one 1114 built for a rookie team so they could have the opportunity/experiance of a FIRST event. It is very similar to the robot 1305 built in the 2006 season. It pretty much has Andy Mark Transmissions and split tracks with the same picker upper and dumper as 1305.
1305 used this robot to compete at IRI this year and it was called Snow town.
It was really nice of 1114 to allow two different teams to use the robot and it competed very competitively. Thanks goes out to Tyler( the main builder) for building an awesome robot.
Hafize
[center]1305 - Iceł - Near North Student Robotics Initiative (NNSRI)
Unread 25-09-2006, 14:05
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
The Orchard Park Patriots are a new rookie team starting for the 2007 FRC season. We’ve been helping them get started for the better part of a year. Our Canada’s Wonderland Off-season event allowed them to experience a FIRST event, without all the pressure of a regional. The competed under with the team number 2000, but this was just a number we gave them to show the other teams competing that they were in fact pre-rookies. They will receive a different number once they officially register.
The robot was build by 1114 for two reasons. 1) to test out the SPAM inspired half-track drivetrain and 2) to give Orchard Park a simple and robust robot to compete with at Wonderland.
Following the 2006 FRC season, it was obvious that while our tank tread drive base was effective, it still had the enormous weakness of breaking treads. Between the Triplets, 195, and 48, I think around 45 break-o-flex, err, brecoflex belts were broken. After GLR, the addition of slider beds and flanged idlers greatly improved this weakness, but the slider beds introduced large amount of friction to the system, totally killing our drive base efficiency. We also made the switch to Gates-Mectrol belts through our local supplier Connect Conveyer. We found these to be considerable stronger than the Breco’s.
The principle behind the half-track was simple… reduce the unsupported distance between the pulleys, and add an extra degree of redundancy to the system. By eliminating the need for slider beds, we were also able to get the efficiency back up to an acceptable level.
In this aspect, the half-track was a success. So far, through testing and two FIRST competitions, it hasn’t broken a single belt. We also found that turning performance was significantly decreased by the half-track design over the traditional single belt design. I believe it has to the increased contact further away from the center of mass. Turning was greatly improved by increasing the drop between the center and outside pulleys. Initially, it was 3/16”, but increased to 5/16” after testing. Turning was also improved by switching to a harder urethane rough top belt backing from the original gum rubber rough top backing.
The overall robot design was largely inspired by 1305’s 2006 robot. As one of the best dumper/defense robots last season, it was the logical choice.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 26-09-2006, 23:34
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Ahem....we broke 1 belt all year, buddy.
Interesting - a new belt source. We shall check it out!
Unread 27-09-2006, 08:15
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
That's OK, we made up you you. I think 703 broke about 10 belts this year! Definitely looking at a design change for next year!
MB
Unread 27-09-2006, 15:03
AdamHeard's Avatar
Lead Mentor
Can we assune tha the triplets will become quadruplets this year?
Unread 27-09-2006, 18:13
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I doubt it.
Unread 27-09-2006, 19:25
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
You can assume whatever you want. There are some changes planned within NiagaraFIRST for the 2007 season, that will be revealed in due time.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 27-09-2006, 19:35
I believe the official count for 195 was about 14 broken belts in 2 competitions.
Unread 27-09-2006, 20:03
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Cool. Now I know how many spares we'll have to order if we decide to use belts.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 28-09-2006, 18:20
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
If I recall, the only reason we broke that belt was because we were trying to see if performance would improve with less tension on the treads. There was too much slop, and we were pushed from the side, resulting in a loose tread twisting off the center idler wheel and snapping the belt. We kept them tight for the remainder of the competition without incident, so tension played a major roll. I was relly happy with only breaking 1 belt in 3 regionals + national + IRI.
We broke several belts in '04, but we used a different tread compound then (i.e. the red natural rubber as opposed to the green super-grip from '06). The green super-grip was definitely softer than the natural rubber, so that may have also played a part in our tread life.
I really like the half-track idea...something to look at, perhaps even prototype.
Most Impressive Manipulator santosh Technical Discussion 28 08-06-2005 22:44
Most Impressive/Advanced/Unique/Cool drivetrain you've ever seen sanddrag Technical Discussion 41 03-06-2005 09:31
Rookies ParadigmShift03 General Forum 2 23-01-2004 17:25
pic: Friday J&J Regional Rookies CD47-Bot Extra Discussion 1 22-04-2003 00:35
Rookies Nick Mac Chit-Chat 5 21-02-2003 11:32
