Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 26-09-2006, 12:41
nobrakes8 nobrakes8 is offline
AKA: Kevin
FRC #4206 (RoboVikes)
nobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud ofnobrakes8 has much to be proud of
Re: What machines are you using? (CNC, lathes, mills, 3-in-1 machines?)
Hardinge Lathe... but they might be too pricey (Hardinge is like the mercedes of lathes..).. If you already have a welder and some power tools... maybe a belt sander, vertical or horizontal band saws would be helpful..
But if you already have that stuff, I'd add another lathe or miller since they get backed up worse and longer than most other tools.
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
State Machines doyler Programming 7 11-01-2005 00:53
pic: machines CD47-Bot Extra Discussion 20 27-02-2004 00:24
Sewing Machines tenfour Kit & Additional Hardware 0 07-01-2003 17:16
# of limbo machines? archiver 2000 16 23-06-2002 23:05
