Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 25-09-2006, 13:29
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Eclipse Visual Editor
I'm using the Visual Editor plugin for Eclipse and am trying to put in an image that the user will be able to plot points on. What component would I use to do this?
Yes, its FIRST related
http://www.mikesorrenti.com/
Unread 25-09-2006, 13:39
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Eclipse Visual Editor
Sounds like you are working on code for a waypoint plotting system for autonomous code.
Unread 25-09-2006, 13:40
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Do you want the source for this? Language is C#. Right-click on the field to add/modify waypoints.
http://members.cox.net/seanwitte/pathplanning.zip
Unread 25-09-2006, 22:04
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Are you using SWT/JFace or Swing? In SWT I believe a Canvas can have an image as a background (check the API) , (and VE is not a very good SWT designer yet, I haven't tried 1.2 though). In Swing, I am not so sure.
Unread 26-09-2006, 18:03
Mike's Avatar
AKA: Mike Sorrenti
I am using SWING.
Sean, thanks for the offer however the school will only let me develop in Java.
Unread 27-09-2006, 10:09
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Why would they force you to use one language?
Unread 27-09-2006, 10:30
I'm guessing he is working on it in a AP Computer Science class.
Unread 27-09-2006, 12:35
Team 2021 Captain
AKA: Chris Davidson
AP Computer Science uses Java.
Unread 27-09-2006, 13:03
Mike's Avatar
AKA: Mike Sorrenti
Well originally I was only using Java because that is all the school's computer had on them and didn't feel like going through the red tape to get something else. Our school doesn't allow us to use Firefox, thats how bad it is.
After a few days of attempting to get work done in Java... I think the trouble of getting permission for C# is worth it.
Unread 27-09-2006, 14:05
prograid's Avatar
AKA: Ben Cherian
I am using SWING.
You can paint onto any Swing component, at least that's what the documentation says. Check this page out for more information. There is also a tutorial specifically on Java2D which will give you more information.
eclipse & Kevin's camera code dasRatsel Programming 22 17-02-2006 12:43
using eclipse dasRatsel Programming 82 02-01-2006 13:20
Eclipse code formatter Astronouth7303 Programming 0 24-12-2005 17:39
Eclipse with CDT Nis Programming 2 15-06-2005 09:31
Last total Lunar Eclipse TONIGHT miketwalker Chit-Chat 16 11-11-2003 22:00
