Go to Post "I want to be like them. We will strive to be like them. Lets get started! :D " - Rion Atkinson [more]
Go Back   Chief Delphi > Other > VEX
Unread 30-09-2006, 04:31
Electrical Engineer
Rookie Year: 1995
Re: PWM Frequency
Originally Posted by Guy_E
All the settings were the same as if I were downloading the program using the orange cable (accept the different COM port).
As far as I know, there is no button to push in the VEX controller.
And my serial port is located on COM 1.
Guy,
When you used the orange USB to RJ11 cable to program the VEX controller, you have to press the button on the cable to do it...
When the orange cable is taken apart at its DB9 connector, the program button is between the DB9 and the RJ11 connectors.
Also, insure that COM1 is set to 115K baud in the Device Manager so that it agrees with the IFI loader.
Mike
Mike Betts
As easy as 355/113...
Unread 30-09-2006, 06:55
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Re: PWM Frequency
Originally Posted by Mike Betts
Guy,
Mike
I think you didn't understand my question. I have a cable, which has nothing to do with the VEX orange cable.
The cable is RJ11 to serial and I want to use it instead of the orange cable.
The reason I want to do it is because I have 2 VEX controllers, and only one cable and I need two (one is not mine). In order to buy a cable I need to buy the entire programming kit which costs about 100$. I want to save my money and use my own cable.
I hope Im clear now...
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 30-09-2006, 12:46
Electrical Engineer
Rookie Year: 1995
Re: PWM Frequency
Guy,
OK... There are three paths which you may follow...
1. Contact IFI via the VexForum and ask how to purchase the cable you want.
2. Contact IFI via the VexForum and ask for a schematic for the DB9 to RJ11 cable (with programming button) and modify your cable appropriately.
3. Take the orange cable which you already have. Using an ohm-meter, trace out each of the RJ11 pins back to the DB9 and determine which pins go where on the DB9 (at least 2 pins should connect). Then determine which pins get shorted out when the programming button is pressed (most likely the 2 unused by the DB9) and modify your cable appropriately.
Best of luck...
Mike
Mike Betts
Unread 30-09-2006, 13:15
FRC #1574 (MisCar)
Re: PWM Frequency
Thank you very much for your advices.
You have helped me alot!
Visit our website:
www.miscar1574.com
Unread 05-10-2006, 17:55
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Re: PWM Frequency
This may seem a bit off topic than what you guys are talking about, but how exactly can you program the vex controller with MPLab?
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 05-10-2006, 23:20
Electrical Engineer
Rookie Year: 1995
Re: PWM Frequency
Exactly the same as the FRC robots. Put another way, If you can program a FRC robot, you can program a FVC robot.
The FVC controller has exactly the same uC as the 2004 and 2005 FRC controllers. The differences due to the hardware "glue" around the uC are almost invisible to most users. In most cases, if you choose your I/O correctly, you can cut and paste your FRC code into a FVC, compile and run.
Do you have a specific question?
Mike Betts
camera update frequency Rickertsen2 Programming 2 14-02-2006 23:07
Max Encoder/Interrupt Frequency? duane Programming 5 23-01-2006 20:43
control loop frequency. Rickertsen2 Programming 1 12-01-2006 08:38
digital output frequency Barth Programming 8 06-03-2005 21:58
Frequency of Offseason Meetings Yan Wang General Forum 13 24-09-2003 11:40
