Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 30-09-2006, 17:31
Andrew Blair's Avatar
FRC #0306 (CRT)
Welded Frame Horror Stories
Ok, our team is considering a welded frame and cantilevered drivetrain for next year, but I've heard many horror stories regarding broken welds, permanently bent frames and destroyed drivetrains because of a dent in a frame member. Tell me your horror stories, what happened, and if it can be avoided. Are welds prone to break in a certain style of game and can less-than-aerospace quality welds withstand tough play, especially if braced properly? Is 1/8" tube capable of an aggressively defensive style of play, and how badly do drivetrains suffer when you're somewhat out of square?
-Sir Francis Bacon
-Albert Einstein
Unread 30-09-2006, 17:46
CraigHickman
Posts: n/a
Re: Welded Frame Horror Stories
As long as you design your fram right with welded members, you won't have any issues. The materials we use is 1/8th inch wall 1x1 box extrusion. It's never let us down.
The only time we broke it was when the bot tipped over and got rammed 8 timed by a tank tread bot. But that was a whole different issue.
So design it smart, and you'll never go back.
Unread 30-09-2006, 18:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
116 has welded our frame for longer than I can recall, and we've never really had any problems with it. The closest thing to anything you're describing we've encountered, that I know of, would be taking about a 1" dent after a vicious ram (while we didnt have bumpers attached). But that didn't really effect us in the long run, as the dent didn't effect our chain. Plus, had we been using bumpers, it would have been a non-issue.
Unread 30-09-2006, 18:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We've used 1"x2" 1/8" wall aluminum tubing the last few years, with great success.
Put a couple cross braces in the center, and you're good to go. We got the heck bashed out of us all year long, and the frame is just as square as the day we had it welded. Haven't had a single issue.
I suppose it helped that a professional welder did all the welds on our frame, but as long as you design the frame properly, you shouldn't have a problem.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-09-2006, 19:03
AdamHeard's Avatar
Lead Mentor
We had a similar frame this year and the fame itself never had any problems. Some other welds on the upper part of the robot broke, but they were from tipping probably.
Unread 30-09-2006, 20:19
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
How to stop deformation from game use? Simple, decent welding and GUSSETS. So many teams never reinforce their joints, and sure that may work for a non stress application, but whenever you get two or more robots colliding, gussets prevent the welds from damaging forces.
Just my $.02
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 30-09-2006, 22:02
travmizer's Avatar
travmizer travmizer is offline
Head of Programming
AKA: Travis Schmidt
FRC #0617 (Springer Express)
travmizer is an unknown quantity at this point
Send a message via AIM to travmizer
MAKE SURE IT'S NOT TOO BIG!
Ours wasn't welded, persay. The main frame, we desighned and got it cast.
When we got it back it was a half inch too long.
We hade to take a grinder to it. (UGH)
Isaac Asimov once said:
If knowledge can create problems, it is not through ignorance that we can solve them.
Unread 30-09-2006, 22:35
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Fusion has been using welded frames and custom transmissions at least since 2003 on Squid bot, the years before that I cannot be sure about except for Flash, Fusion's first robot, that has a welded frame if I remember correctly. We have not had any trouble with the frame, but at IRI in 2005 with Arm-N-Ra our arm was welded to a gear, and the weld broke and our arm came crashing down, but that was a weak point in the design of the robot. 5 more ounces of aluminum would have saved us. Also at IRI 2006, a chain in our transmission lost its master link lock and fell apart. Those are the only two problems Fusion has had with the robots in the past 2 years.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 01-10-2006, 00:07
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
We use welded frames and we have had no problems, except when we pre-drilled the bearing holes and they warped . The frame was put to the test when we were auto programming and the robot was setup backwards then went forwards at full speed into the cement curb; lets just say the curb lost.
Eat, Sleep, Build Robots
Unread 01-10-2006, 03:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
6063 Aluminum 1/8" wall box tubing TIG welded for past 3 years never had any problem worth doing something about.
Unread 01-10-2006, 11:28
FRC #0306 (CRT)
Can you elaborate on how bad of a problem this was? Did they warp a few thousanths, or turned into ellipses? I'm trying to compile as much info on problems as possible so we may avoid them should we decide to move to welded.
Additionally, if you pop a weld in competition, whats the best way to fix it? Carrying a TIG welder in with us is not especially convienient.
-Sir Francis Bacon
-Albert Einstein
Unread 01-10-2006, 11:44
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Bandage it, use a piece of aluminum plt and lots of pop rivets. No harder than fixing a broken gusset if you don't weld.
Unread 01-10-2006, 12:16
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Here are a few lessions learned from the ONE year we welded...
- Don't let you welder learn on the robot frame
- Don't let you welder learn TIG welding as his first kind of welding
- Don't let you welder learn on aluminum
- Don't let you welder learn on 1/16" thick aluminum
- Don't let someone grind off all the "ugly bumps" on the surface after you are done welding.
We made some mistakes. Huge mistakes. But if you have a skilled weldor on the team, you should be OK.
And here is my thinking on bent frames. "Assume" that your frame will bend. Now how does your robot work? Try to think of ways to design so that it will work WITH damage. Because if you are anything like our team... you are going to eventually run it into a wall at top speed, fall over, or drive it off a cart at some point.
Brian Graham
Unread 01-10-2006, 12:17
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Get some practice! Especially if you want to use aluminum, we have had a professional machinist do some of our welding, and the first time he did it it broke (luckily before it got out of the shop) and he's been welding for at least 40 years...and small mistakes happen a lot with aluminum, any one will tell you that. Anyway, he hasn't had a problem since then, but he always does a test run with the same alloy before you weld.
If your looking for an alternative to welding thats still light and easy to fix, my team has been very happy and slightly fascinated by the latest rage in the facing industry, Screw Rivets! (Look up Rivet Nuts on McMaster for more info)
Kind or works like this
/off topicness
Unread 02-10-2006, 08:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I thought the fastening 306 did this year was a neat idea just really machine work intensive, I talked to one of your mentors about it at Philly.
We use 1"x1"x1/16" AL 6061 box for our frame and had no issues with breaking anything. We planned for a high impact game last year and built a properly reinforced ladder frame to handle the load. The only damage that our frame showed after 2 regionals, the championship and Battlecry was on the front where there is a slight indent (~1/8").
I don't believe cantelievering will be an issue if you support it right but I don't reccomend unless you protect you wheels well.
A couple other comments:
Don't pre-drill your mounting holes before welding. Assume you will have some misalignment/warping from the heat of welding.
TIG!
Drill vent hole to allow hot gas to escape when closing a box.
Bolt to the frame properly. I.E. don't put a bolt all the way through the box and crush it, use rivnuts.
1x1x1/8 angle weighs the same as 1x1x1/16 box. Sounds stupid, but people forget. Also 1x1x1/8 weighs almost the same as 1010 8020 extrusion.
Thank-you 294 & 67
www.bobcatrobotics.org
Computer Horror Stories Pat McCarthy Chit-Chat 24 29-11-2005 13:46
Final... It's all over.... (Horror Stories Of The Aftermath) Baden3DMAX13 3D Animation and Competition 10 15-03-2005 14:48
Welded Box Tube tenfour General Forum 5 27-01-2004 18:54
Hotel Horror Stories Breanne M Chit-Chat 55 25-04-2003 23:42
Image Discuss: 190 Welded Battery Connectors CD47-Bot Extra Discussion 7 21-02-2003 16:04
