Go to Post This is where a tenacious NEM comes in very handy. - Mark McLeod [more]
Unread 30-09-2006, 15:53
travmizer's Avatar
travmizer travmizer is offline
Head of Programming
AKA: Travis Schmidt
FRC #0617 (Springer Express)
travmizer is an unknown quantity at this point
Send a message via AIM to travmizer
Question IFI Loader doesnt open .hex file
Ok, so we have till the end of monday to get the robot to work,
I'm the new replacement programmer, and I cant get the loader to work. It's been really bugging me.
It opens, and I click "Browse". When I click on the camera.hex file and press open, I get an alert message. This is about what it reads:
Run-Time Error "76"
Then when I press "OK" It closes IFI Loader.
Could someone please at least give me a hint as to what I should do?
Any help you give would be, well... helpful.
Thank You!
Isaac Asimov once said:
If knowledge can create problems, it is not through ignorance that we can solve them.
Unread 30-09-2006, 16:07
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: IFI Loader doesnt open .hex file
Try moving the camera.hex file to a different directory. I believe that Runtime Error 76 in VB6 means that the directory wasn't found. It could be because it's too long of a path.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 30-09-2006, 21:56
travmizer's Avatar
Head of Programming
AKA: Travis Schmidt
Thanks Matt!
I've had problems like that before, so your probably right.
Now I'm ganna burn with anxiety waiting till monday to try it out.
Unread 30-09-2006, 23:28
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
76 -- Path not found
Unread 01-10-2006, 11:56
ScottWalls ScottWalls is offline
FRC #0245 (AdamBots)
ScottWalls will become famous soon enoughScottWalls will become famous soon enough
Yes, move the hex file to a shallower directory. IFI_Loader can't read long file names. I would recommend moving your whole programming folder further down the file tree.
Unread 02-10-2006, 13:33
travmizer's Avatar
Head of Programming
AKA: Travis Schmidt
Errr, it didn't work, can you maybe give step by step directions?
Would be very appreciated
Unread 02-10-2006, 13:41
travmizer's Avatar
Head of Programming
AKA: Travis Schmidt
Post Re: IFI Loader doesnt open .hex file
btw: the file with the location is 31 characters long:
C:\mcc18\frc_camera\camera.hex
and the full alert message is:
Run-time error '76':
Path not found
after this alert comes up, it exits the Ifi_loader program
Unread 02-10-2006, 14:20
travmizer's Avatar
Head of Programming
AKA: Travis Schmidt
Ok, sorry for posting 3 times in a row, but i just found this link:
http://www.ifirobotics.com/forum/viewtopic.php?t=96
It's about how the loader only accepts files under 32k. I have a feeling mine is 70k, but I'm working on that.
If anyone's got suggestions, they would be appreciated A LOT AND BUNCH!
Unread 02-10-2006, 14:26
travmizer's Avatar
Head of Programming
AKA: Travis Schmidt
Exclamation Re: IFI Loader doesnt open .hex file
or... maybe not?
program memory utilization is 19%
well.. the .hex file is 70k, but the program is apparently not
but i figured the problem, i was using another copie of IFI_loader, so i have that down.
but now, when i press download, (ive pressed the prog button) it says "device found" untill i get an alert-
Runtime error "11"
Division by Zero
any ideas about what this means?
(sorry about all the posts)
Unread 02-10-2006, 16:17
Team 2021 Captain
AKA: Chris Davidson
Im glad you have found a solution but please learn to use the edit button. 5 posts is a little much.
Unread 02-10-2006, 20:45
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
It means exactly what it says - IFI_Loader attempted to divide by zero. Why it is dividing, I don't know.
If you're feeling brave, you can try PICLoader or pycloader (C vs. Python). http://sf.net/projects/ifi-picloader I wrote pycloader, so any problems you have with it I'd love to hear about. (I think it might be better implemented than the original IFI loader.)
I cant get my program into a hex file Serge Programming 8 17-02-2006 03:28
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
hex file garbage? sciguy125 Programming 2 04-07-2005 23:04
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
