Go to Post Life is more fun if you take some risks every so often. - Andy Baker [more]
Unread 02-10-2006, 23:15
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Camera Programming
I was wondering, does anybody have some code that they used to get the robot to respond to the cameras values? Last year we got our camera to track but we couldn't figure out a way to use those values to make some code that would work. Any help is greatly appreciated.
Unread 03-10-2006, 15:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Camera Programming
I've used Kevin's code the last two years, modifying this year's code to set the camera to autotrack and report servo values.
To handle the camera, you need to:
  • Call the initialization function, Initialize_Camera(), in User_Initialize()
  • call Camera_Handler() on a regular basis (the slow loop works)
The data is dumped into the variable T_Packet_Data. It contains (by default):
  • The upper left and lower right points of the bounding box of the color blob (x1, y1, x2, y2)
  • The median of the color blob (mx, my)
  • The number of pixels in the blob
  • A "confidence" value (which is proportional to the number of pixels)
See camera.h for details.
If you have done all this, and are having problems getting the robot to "respond", you will have to go into more detail.
Unread 04-10-2006, 21:59
FRC #0935
Thanks, I'll try that and see what happens
****Team 40 Checkmate easyC Camera Programming Workshop**** Kingofl337 Programming 0 05-09-2006 16:21
Need help Programming and wiring camera! Amisca Programming 1 14-02-2006 18:37
Camera doesn't have firmware? no programming? GraphicArtDesig Programming 6 19-01-2006 20:10
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Should there be a section for the 'camera' under 'Programming' Bharat Nain CD Forum Support 6 25-01-2005 22:23
