Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 05-10-2006, 16:59
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
RC stuck in "Program State"
Hey, we need to take our 2005 robot over to a highschool for a presentation, but the controller is in "Program State". I dont know a whole lot about controllers.
Both the remote on the robot and the transmitter on the OI are in "Standby" mode. Sorry for my "newbie"-ness but I need to leave in about an hour, and I can't get ahold of any of our mentors or programmers.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 05-10-2006, 17:10
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: RC stuck in "Program State"
Andy-
Check your PM's.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 05-10-2006, 17:25
AndyB's Avatar
AKA: Andy Burchardt
Yeah, still not working. The symptoms are this:
Battery Power = Blinking Green
Program State = Solid Green
Radio Modem = Solid Orange
RC Hardware = Dark
RC Mode = Dark
We are also reciving on OI
No Data/Radio = Red
We have a radio hooked up to it.
Unread 05-10-2006, 17:28
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RC Hardware = Dark
RC Mode = Dark
No Data/Radio = Red
Sounds to me that you have a bad serial cable from the radio to the robot controller.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-10-2006, 18:05
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Try teathering it and restarting... then just try pressing reset or hold the program button and then reset or press the reset again... it happened to my once and i teathered it and just played around with it..
Good luck
Unread 05-10-2006, 22:37
AKA: Dr. Brooks
no team (WRRF)
There is a controller fault, producible with bad software, where the controller won't run and the program state light is on, while it really is not in program state. If leaves you stuck because it indicates program state but won't load a new program. The controller will come up in this same state every time you power it up, so power cycling it does not clear the problem.
In this case, hold the program button down the right number of seconds to put it in program state, it was 3-4 seconds as I recall, but don't expect any light changes to indicate anything. Then load a program that is known to be good and this should get you going. You can then re-try loading the possibly errant program and learn that it is in fact the errant program that is causing the problem.
Eugene
Unread 05-10-2006, 22:50
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
this happened to us at the nj regional. all i remember is that there is a complicated button combination you need to press. if you can look up more about the controller you might be able to find it.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 06-10-2006, 11:22
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
RC Hardware = Dark
RC Mode = Dark
No Data/Radio = Red
Solid Green, code not executing, Orange Radio light, it doesn't see the radio.
Code doesn't begin execution until the first packet of OI data is received, so it sounds like a communications issue. If you wish to try a master reset you must hold both program and reset buttons for ten seconds after power up, release reset and hold program for a few more seconds, you should only get two LEDs lit on the RC, from there redownload your program and reset. Also check your cables from RC<->Modem, perhaps a tether would be good to ascertain it is in fact a communications problem.
And I did all of that from memory, so it might be a bit fuzzy here or there...
Oh and congratulations, you broke my anti-CD policy, stinking FIRSTers..can't get rid of y'all.
Matt Krass
Unread 06-10-2006, 14:17
AndyB's Avatar
AKA: Andy Burchardt
The correct answer was: Bad OI radio, but I found the tether cords so it was working at the demo. Thanks for your help everyone.
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
Program error - "can not fit the section" miketwalker Programming 9 20-02-2005 01:21
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
"Timer Loop" Program Brett W Programming 16 25-02-2003 13:52
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
