Re: RC stuck in "Program State"
Andy-
Check your PM's. |
Yeah, still not working. The symptoms are this:
Battery Power = Blinking Green Program State = Solid Green Radio Modem = Solid Orange RC Hardware = Dark RC Mode = Dark We are also reciving on OI No Data/Radio = Red We have a radio hooked up to it. |
Try teathering it and restarting... then just try pressing reset or hold the program button and then reset or press the reset again... it happened to my once and i teathered it and just played around with it..
Good luck |
There is a controller fault, producible with bad software, where the controller won't run and the program state light is on, while it really is not in program state. If leaves you stuck because it indicates program state but won't load a new program. The controller will come up in this same state every time you power it up, so power cycling it does not clear the problem.
In this case, hold the program button down the right number of seconds to put it in program state, it was 3-4 seconds as I recall, but don't expect any light changes to indicate anything. Then load a program that is known to be good and this should get you going. You can then re-try loading the possibly errant program and learn that it is in fact the errant program that is causing the problem. Eugene |
this happened to us at the nj regional. all i remember is that there is a complicated button combination you need to press. if you can look up more about the controller you might be able to find it.
#7
Code doesn't begin execution until the first packet of OI data is received, so it sounds like a communications issue. If you wish to try a master reset you must hold both program and reset buttons for ten seconds after power up, release reset and hold program for a few more seconds, you should only get two LEDs lit on the RC, from there redownload your program and reset. Also check your cables from RC<->Modem, perhaps a tether would be good to ascertain it is in fact a communications problem. And I did all of that from memory, so it might be a bit fuzzy here or there... Oh and congratulations, you broke my anti-CD policy, stinking FIRSTers..can't get rid of y'all. ![]() |
#8
The correct answer was: Bad OI radio, but I found the tether cords so it was working at the demo. Thanks for your help everyone.
| New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" | Jessica Boucher | Team Organization | 0 | 10-08-2005 10:55 |
| Program error - "can not fit the section" | miketwalker | Programming | 9 | 20-02-2005 01:21 |
| "Thunderbirds" Vs. "Team America" Which one will rule the box office? | Elgin Clock | Chit-Chat | 3 | 07-09-2004 19:53 |
| "Timer Loop" Program | Brett W | Programming | 16 | 25-02-2003 13:52 |
| how tall is the ramp when in "up" and "balanced" position??? | archiver | 2001 | 1 | 24-06-2002 00:54 |
