Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 04-10-2006, 17:41
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Small edu code: PLZ HELP!!!
I need a copy of the small EDU code with an updated library file. the computer that can compile the copy we have is...dead, and our best computer won't compile the same code because the library file is out of date. Kevin does not have the code on his website. Does someone have an updated copy, or a library file that will work?
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 04-10-2006, 19:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Small edu code: PLZ HELP!!!
http://www.ifirobotics.com/edu-rc.shtml
Unread 05-10-2006, 06:59
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Originally Posted by Astronouth7303
I seem to be getting a 403 error on all of IFIs pages. Is anyone else getting this?
Unread 05-10-2006, 17:36
FRC #0599 (Robodox)
i tried the link, but it said that I am not able to download because of a high security alert thing. I am not sure if you got the same thing, but could someone please check it out? also, I believe that the library file is not compatible with the updated version of MPLab C18 compiler. I need an updated version of the library file.
THE ROBODOX FORUM
Religion: Haruhiism
Unread 05-10-2006, 19:48
AKA: Jamie Bliss
No version of MCC18 other than 2.4 will work, IIRC. If you are using any other version of MCC18, you need to change that.
The only libraries that work with the controllers come from IFI. None of us have "updated" versions.
Unread 05-10-2006, 20:15
Team 2021 Captain
AKA: Chris Davidson
Whatever it was, it works now.
Aim high poster help plz? Clam Website Design/Showcase 3 07-02-2006 21:26
Gear Ratio help....plZ..someone??? Instigator Technical Discussion 15 30-01-2004 17:52
Missing Item plz help! Cory Chit-Chat 12 06-05-2003 00:39
Plz help with codec Chris Nowak 3D Animation and Competition 7 18-02-2003 16:15
HELP W/ CONVERTING FILES PLZ... Matt Attallah Chit-Chat 3 03-01-2002 18:47
