Go to Post (This is why Non-Engineering Mentors make the dinner plans for the team...) - KathieK [more]
Unread 09-10-2006, 22:09
Insomniacsloth's Avatar
Insomniacsloth Insomniacsloth is offline
Team Captain/Manager
AKA: Zak Rogoff
FTC #3283 (Lord Wellington's Beef Trapeze)
Insomniacsloth is an unknown quantity at this point
Send a message via AIM to Insomniacsloth
Tracking Lines In Hangin' Around
Can I use the line sensor kit to track the white lines on a grey background that are on the floor of the Hangin' Around field. If so, how much programming is necessary?
Unread 09-10-2006, 22:15
AdamHeard's Avatar
Lead Mentor
Re: Tracking Lines In Hangin' Around
Those sensors return a value of 0-255 depending on the reflection it is getting. With those sensors one end will be full reflection (that'll be the end the white tape is near) and the other will be no reflection (the end the grey will be close to there). From these values you can tell whether the sensor is over the white part, or the grey part. I can't tell you the specific values for these, you have to plug it in and test it.
From there you tell it to drive the motors the way you want based on where you are. (I won't spoil this part for you).
If you know C, this shouldn't be difficuly in MpLab.
If you don't, It would be best to use EasyC.
Unread 11-10-2006, 14:47
christinedevrie christinedevrie is offline
FRC #1302
christinedevrie is an unknown quantity at this point
Smile Re: Tracking Lines
What is the best way to teach my students to write a line tracking program? Are there any tutorials for them to use? Thanks, Chris de Vries
Unread 11-10-2006, 15:25
Billfred's Avatar
Billfred Billfred is offline
Re: Tracking Lines
As someone who's had a hand in programming a few line followers of the Mindstorms nature, the best advice I can offer here is to act like you're the robot. You've got three readings, one from each sensor in the line follower kit. What do you do if your left sensor is reading what is most likely a white line? (How long do you do that for?) The right sensor? What if none of the sensors are seeing the line?
Be the robot (no, not like that), and it should be pretty easy to figure out.
Naturally, I'm assuming that you know how to program your robot to move autonomously at all. If not, you'll want a lesson in EasyC or MPLAB first.
Unread 12-10-2006, 15:25
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
There's a simple line-tracking example program in this rookie's guide:
http://www.chiefdelphi.com/media/papers/1871
It uses one sensor, which is not the most efficient means of line-tracking, but it's a way to get started.
Unread 15-10-2006, 13:28
AKA: Zak Rogoff
Thank you. I give to my programmers.
Nitmoogle built it better than me!
Hangin'-A-Round -- Official Game Discussion Chuck Glick FIRST Tech Challenge 61 18-10-2006 08:34
Hangin'-A-Round Animation Kevin Thorp FIRST Tech Challenge 21 18-09-2006 23:34
pic: 11 Hangin with 1319 CD47-Bot Extra Discussion 3 20-04-2004 18:08
pic: MAK Team 211 Hangin' CD47-Bot Robot Showcase 9 26-02-2004 20:38
pic: SPIKE's Hangin' Out CD47-Bot Robot Showcase 4 18-02-2004 23:03
