Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-10-2006, 15:48
Craig1989 Craig1989 is offline
FRC #0539
Craig1989 is on a distinguished road
Wheels
Hey Guys,
I'm looking to purchase some new wheels for our robot, to do some drive train experiements for an upcoming scrimage and next year.
I'm looking to purchase:
2 Omniwheels
4 Regular drive train wheels
-Ideally these should be around 4 or 5 inchs in diameter but 6 is fine too.
-Also if at all possible they should have a 5/8 bore with keyway.
I've looked hard and found some possible ideas, however if I could get some links from people who have actually used the wheels I would really appreciate it.
Thanks
Craig
Unread 10-10-2006, 16:09
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: Wheels
I would suggest IFI Robotics for the regular wheels...their traction wheels are unbeatable in my opinion. We used them last year and had no problems with them all year, other than having to replace tread since it was worn out but that was expected.
MechWarriors 573
Unread 10-10-2006, 16:21
FRC #0539
Re: Wheels
We had looked into those wheels, however felt they were a little on the expensive side... While we are not ruling out the option we just want to look around a little more.
Unread 10-10-2006, 16:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Wheels
Check out http://andymark.biz/products.htm
They have two varieties of 6" and 8" omni-wheels (aluminum and plastic). They also carry 4", 5", & 6" Traction wheels. The traction wheels are built to use dead axles, but AM also carries a "Universal Hub" with a 1/2" bore and 1/8" keyway. You could either modify your shafts to 1/2", build your own hubs, or modify their hubs to fit your shafts. Depending on your robot design, they shouldn't be too much of a problem.
Unread 10-10-2006, 17:37
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Re: Wheels
if you are looking for "normal" wheels you can tryskyway wheels
they have a large selection, at decent prices, if you don't find what you are looking for on the web page, just give them a ring, their quite happy to help you in your search.
Blargha!
Unread 10-10-2006, 17:53
AdamHeard's Avatar
Lead Mentor
Re: Wheels
If you are short on cash you can make nice treaded wheels from skyways. like this
Our team did the same thing the last two years with the waffle tread.
Unread 10-10-2006, 23:07
dtengineering's Avatar
AKA: Jason Brett
Re: Wheels
I've seen some nice, cheap, simple wheels made of a couple pieces of MDF glued together with tread screwed to the outside. Counterbore with a forstner bit for a couple of bearings, and bolt a sprocket to it with a bit of a stand-off and you might be surprised how cheaply you can build a wheel. Go back with a holesaw and cut out some "speed holes" and you might be surprised how lightweight the resulting product is.
If you wanted them to look really nice, use baltic birch plywood, inlay some purpleheart and black walnut, and give it a nice hard varnish finish...
Jason
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
wheels cvanwolbeck Robot Showcase 6 07-10-2004 16:34
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wheels maxgebhardt Kit & Additional Hardware 5 09-01-2003 22:37
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
