Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Unread 10-10-2006, 19:13
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Lightbulb 698's Fisher Price Motor Fix
For this year's game we (698) used one fisher price motor to run our spinning wheel for our poof-ball launcher. We did have one issue that I would like to announce and tell how we have fixed it.
We quickly found that the life of the motor was around 800 poof-ball shots, then it would have to be replaced, mostly because we were burning up the motor . Recently when we were redesigning the launcher to shoot shirts, I came across one of our past "dead" motors. I found that the reason the motor was failing was due to the fact it was overheating. The reason it was overheating was the little white fan (on the inside) was made of plastic and whenever the motor would heat up too much, the fan would melt off of the tiny axle and become worthless.
While redesigning the robot we added two 12vdc victor fans to the top and bottom housing for the motor mount. The forced airflow has extended the life of the motor greatly! I would recommend this to any FIRST team with similar problems.
Unread 10-10-2006, 19:15
AdamHeard's Avatar
Lead Mentor
Re: 698's Fisher Price Motor Fix
We did this last year for the fisherprices on our arm and it worked well.
Unread 10-10-2006, 19:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The fisher price motor is so easy to cool it is a wonder why more teams don't do it, yet still complain about them burning up. A simple RC car motor heat sink, some thermal paste, and a zip tie is often all it takes. A little fan isn't a bad idea either. pic
Unread 10-10-2006, 22:07
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
The 2005 Fisher-Price motors were prone to overheat so one of our students designed this:
http://www.chiefdelphi.com/media/photos/20111
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 10-10-2006, 22:51
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
we fixed this problem by taking out the last two gears in the case to ease tension on the motor, it also the right speed we wanted to shoot at, as well as took some heat sinks, and bent them around the motor. Both of these kept the motor cool and running, and im sure we have shot well over 1000 shots with that motor already. Try that, it works for us.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 11-10-2006, 13:14
Did anybody notice that there is some ventilation holes in the end bells of the motors? If you cover these holes, no cooling air goes in for the fan to push out.
Unread 11-10-2006, 13:19
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Yes, that is an oft overlooked aspect of the issue. Good reverse engineering on the fan melting issue and that aluminum cube is sweet!!
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 11-10-2006, 13:23
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
67 had an issue with the 2005 HOTBOT's Globe motor, that ran our rear turret, overheating. We mounted a small muffin fan to the frame right next to the motor and had no overheating problems after that.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 12-10-2006, 14:54
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
We have wire tied the small muffin fans directly to the FP motors. Normally we take .060" lexan or aluminum, mount the muffin fan to that and bend to provide a shroud around the motor.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 13-10-2006, 00:17
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Definitely not something new, the problem has been there for a few years now. The FP's are notorious for magic smoke. 217 and 233 use them every year with a lot of success though. 217 uses them in there drivetrain sometimes one per side and adds more power and speed to there transmissions. 233 used them for there shooter wheel this year, two combined and last year used them to extend and retract there arm in a combined gearbox. Again a fan is a fine idea, but make sure your not over working the motor, especially the FP's there not made to take a heavy load. There purpose is to run for long periods of time at a certain fixed rate, remember there used in power wheels cars. Just my two cents on the Fisher price motor topic.
-Good luck,
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 13-10-2006, 19:55
In 2005, we were concerned that we would overwork the FP's, so we a created a shroud consisting of four fans and cube of aluminum. Since we were using the FP gearbox, we added a spacer to the motor mount. This allowed space for air to get to the front of the motor and blow through and cool off the inside of the FP, not just the outside.
Locking the Fisher Price Motor xxlshortys Motors 10 24-02-2004 21:24
need a Fisher Price motor urgently Max Lobovsky General Forum 2 24-02-2004 14:29
Fisher Price Motor Mounting Ashley Weed Motors 1 16-02-2003 19:29
Fisher Price Motor .. Important! Paul Copioli Motors 7 22-01-2003 13:55
Fisher price motor gear specs archiver 2000 4 23-06-2002 23:23
