Go to Post There is no rule that specifically states that you must obey the law of physics during the competition. This may be an oversight. - bmather [more]
Unread 11-10-2006, 08:10
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
Re: pic: Fighting for the atlas ball
Originally Posted by cromat44
So, How was pushing the atlas ball? reliable? difficult?
With these robots, and don't forget they only had a few hours to design and build them, it was more difficult to get up on the platform than it was to push the ball. There was a couple of matches where it came down to a test of strength, with robots on opposite sides of the ball trying to push the it (and the other robot) to their side of the field.
And the ball does NOT roll in a straight line!
Unread 11-10-2006, 15:48
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Indeed the ball is pretty tricky. We found out when 2 130+ lb robots went flying into the ball, some interesting stuff tends to happen:
Ball gets under other bot and they go bouncing back
Surprisingly the ball never popped during the match. It should still be interesting on the VEX scale. lol
Unread 11-10-2006, 16:15
Fuzzy's Avatar
Fuzzy Fuzzy is offline
AKA: Mark Hawthorne
FRC #0011 (Mount Olive Robotics Team); FRC #0190 (Gompei and the Herd)
Fuzzy is a jewel in the roughFuzzy is a jewel in the roughFuzzy is a jewel in the rough
Send a message via AIM to Fuzzy
Is the ball weighted in a certain part?
Unread 11-10-2006, 16:50
Billfred's Avatar
Billfred Billfred is online now
Assuming the Atlas ball is, in fact, the same as the 2X ball from 2004, then yes, some parts of the ball are heavier than others. I assume it's just a variation in the manufacturing process, but that's why you'd never see the 2X ball on the platform with the 2X aligned like it was on the mobile goals--you simply had to let the ball roll to its sweet spot, then center it on the platform.
(If you looked carefully on the balls in Atlanta, and perhaps elsewhere, you would see a little X on the top of where the ball would naturally rest. It really did speed the process.)
Unread 12-10-2006, 08:54
Carol's Avatar
FRC #0365 (MOE)
Yes, the ball isn't symmetrical. And surprisingly the heaviest part of the ball isn't necessarily the plug where you inflate it. If you look closely at the picture, you can see two small dots at the upper right. They are used as the "sweet spot" as Billfred said to help balance the ball on the toilet flange.
pic: Closeup of atlas ball Carol FIRST Tech Challenge 6 19-09-2006 23:47
pic: Joe Troy studying the atlas ball Carol Extra Discussion 9 19-09-2006 18:57
Robocode: Learning JAVA the fun way. While fighting with robots. Denalin Fusion Chit-Chat 2 26-09-2005 23:22
Fighting the goals... archiver 2001 3 24-06-2002 00:51
Potential Problem with "fighting over the goal" Kyle Fenton General Forum 4 17-02-2002 10:21
