Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 13-10-2006, 09:43
KWB@FIRST KWB@FIRST is offline
KWB@FIRST is an unknown quantity at this point
Question Gate Ramps
There must be a logical reason why ? We are asking that there isn't any adhesives put on the field parts. We try and make all the fields the same. However this past season there was black tape applied to the bottom of the gate ramps.
Is there a good reason for this, like cutting down on the reflection, or protecting the floor ?
If there was a good reason, we would like to know what it is ?
Looking for a little insight.
Unread 13-10-2006, 16:12
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Gate Ramps
care to elaborate?
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 14-10-2006, 19:57
FIRST Rocks's Avatar
FIRST Rocks FIRST Rocks is offline
AKA: Matthew Zagone
FRC #0494 (Goodrich Martians)
FIRST Rocks is just really niceFIRST Rocks is just really niceFIRST Rocks is just really niceFIRST Rocks is just really nice
Re: Gate Ramps
On the fields I saw, the gate ramps had black and yellow warning tape on the top edge of the ramps for safety. I didn't see any black tape on the underside of the ramps, and I helped set up a field, so I got a pretty close look.
2009-Attending: Kettering District, Lansing District, Michigan State Championship, & Championship
2008-Attended: St. Louis Regional, West Michigan Regional, Great Lakes Regional, Championship, MARC, IRI, & Kettering Kickoff
2007-Great Lakes Regional Finalist, West Michigan Regional Winner, IRI Winner
2006-Buckeye Regional Winner, Wisconsin Regional Finalist
2005-Finger Lakes Regional Winner, Detroit Regional Finalist
2004-Archimedes Division Winner, Championship Winner
2003-Peachtree Regional Winner, Curie Division Winner, Championship Finalist
"There is no try. Only do, or do not." - Master Yoda
Unread 15-10-2006, 07:51
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Re: Gate Ramps
Yes, the gate ramp has two side to it. One side flips up when the gate is closed (the inside or the game field side). On some field gate ramps this side of the ramp has caution tape on the bottom; the side that will face the robots. (I guess the robot needs to know).
I did notice the last field I setup at NEXTFEST did not have the caution tape applied to the bottom.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 16-10-2006, 07:10
AKA: Matthew Zagone
Re: Gate Ramps
I helped setup the Einstein field at Kettering Kickoff. On that field, the ramps had black and yellow striped warning tape on the field side of the ramps on the top (when the ramp is down).
Unread 17-10-2006, 08:16
Re: Gate Ramps
No............ not the danger tape, we here at FIRST put that there. If the gate was closed and the ramp was up, ready for competition, the ramp that is up facing the field was covered with black tape. This wasn't all the fields, only a couple.
We were wondering if it was causing reflection, interfering? The only two thoughts we had was either to protect the floor, or glare. If it is a big problem we change change it.
Unread 17-10-2006, 10:54
Billfred's Avatar
Billfred Billfred is offline
Re: Gate Ramps
I don't recall seeing any tape on the underside of the ramps on the fields I saw (although since I went to Florida, Peachtree, and Palmetto, I more or less saw the same field three times).
I couldn't really picture reflection being an issue (the dull side of the ramp's diamond plate is facing into the field, plus there's all that diamond plate on the ramp and player station walls that wasn't taped), but carpet protection sounds plausible. I know many gatekeepers are less than graceful when it comes to setting down the ramp (it was more of a swift kick whenever I did it), so doing that some 200 times over a regional (doubled if your carpet goes to two regionals) could -maybe- do something to the carpet in that part of the field. I have absolutely no scientific evidence to back that up, though.
Unread 17-10-2006, 12:16
Re: Gate Ramps
I think your right, it was more to protect the floor. I didn't think with the carpet that would have been much of an issue. Maybe someone got bored, or needed to waste some tape.
I guess we will move on making this a non-issue, way more important stuff to worry about. Thanks for your view though, much appreciated.
Unread 17-10-2006, 12:55
no team (NYC FIRST)
Re: Gate Ramps
There was a safety issue with the ramp in the up position. It can be a big hazard if the ramp was dropped during the opening of the gate at the end of a match. Referees, students and volunteers are known to just jumped the fence and their foot may land near or on the foot-print of the ramp.
I know at the NJ and NYC regional there was some concern about the ramp dropping down with someone near it. Instructions for the "Gate Keeper" was to drop the ramp first before anyone (referees and volunteers) start entering the field area.
I would assume at the off-season comps the rule are a little more lax. Maybe that is why "caution" tape was added. Somebody saw the hazard and was proactive.
Unread 17-10-2006, 17:08
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Gate Ramps
At one of the regionals I attended (either New England or Boston, don't remember which), the volunteers heard some complaints from the crowd that the undersides of the ramps (when up, in active match position) were reflecting the stage lighting to the point where there were blind spots on the field because it was so bright. Someone came up with the idea of using the black tape used for patching carpet holes to cover the bottoms of the ramp to prevent the glare. The tape did the trick- didn't hear any complaints after it was applied.
Unread 17-10-2006, 17:18
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Gate Ramps
Seeing as a field rep from FIRST is actively participating in this conversation, I will take this opportunity to express my concerns over another aspect of the field without going too crazy here.
The locking mechanism with which the gates were secured to the railings (the slide knob and the inside pole part) was always getting stuck and edges from the slot it was sliding in were very sharp at times.
I did cut myself one time up at Mayhem on the Merrimack unfortunately opening this gate system and would like to have the field design crew at least think of some alternatives in the future to the slide locking mechanism.
I'm sure I'm not the only one who experienced this problem, and I realize it must of had to be related to the constant beating the field border railing takes in match after match but there must(?) be a better alternative.
Thanks
-Elgin
Unread 17-10-2006, 23:38
no team (NYC FIRST)
Re: Gate Ramps
-Elgin
I 2nd Elgin's point.
Cuts and pinches are common with the sliding mechanism.
And the knot from the sliding bolt has came off in my hand several times.
Unread 17-10-2006, 17:19
no team (NYC FIRST)
Re: Gate Ramps
Another case solved for the CSI:FIRST team.
Unread 17-10-2006, 17:21
Re: Gate Ramps
Darn.. I opened another case for them. See my last post. lol
Is anybody staying at the Renaissance World Gate archiver 2001 2 24-06-2002 03:10
Sticking Ramps and Fat Goals! archiver 2001 5 24-06-2002 01:47
Overall Dims of ramps & field from CDI 1999 archiver 2000 0 24-06-2002 00:08
