Go to Post We might just dip the entire bot in a Locktite bath before bagging. - Kevin Ray [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 13-10-2006, 12:47
Dylan's Avatar
Dylan Dylan is offline
FRC Mentor
AKA: Dylan Stoll
FRC #0830 (Rat Pack)
Dylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud ofDylan has much to be proud of
Send a message via AIM to Dylan Send a message via Yahoo to Dylan
Pnuematics?
I'm helping the local FLL team out this year as sort of an advisor (I know the coach), and I was wondering if pneumatics are allowed on the robot. The rules do say that there is no limit on non-electric components as long as they are in "factory condition", but it does not mention pneumatics.
If they are allowed, has any one used them before? If so, what kind of success did they have?
The team will be using the NXT system.
"It's like timing a monkey!"-me (explanation avalible by PM request)
"You can't spread Democracy with the barrel of a gun" ~ Helen Thomas
2006 Great Lakes Regional Semi-Finalists (Thanks to our allies: Team 66 and Team 68)
Thanks 469 for lending us your old OI in ATL!
Unread 13-10-2006, 12:55
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Pnuematics?
Pneumatics are allowed in FLL. I totally forgot about the Lego Pneumatics. Are they still available though? I was originally thinking the little pneumatics designed for VEX, or even smaller pneumatics you could use in an antweight battlebot.
Unread 13-10-2006, 12:57
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Pnuematics?
I believe pneumatics are legal as long as they are in factory condition with the exception of tubing that you may cut to required lengths. I don't see a mention about it in the 2006 rules, but I remember something from previous years.
You way want to submit it to the Q&A just to be sure.
Also, http://www.fll-freak.com/faq/faq_printer.htm is an unofficial FAQ but Skye does a superb job keeping it accurate.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 13-10-2006, 13:31
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: Pnuematics?
There are special FLL pnematics that are legal, I believe.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 15-10-2006, 14:20
Best Available Data
FRC #1778 (Chill Out!)
Re: Pnuematics?
One the the most inventive solutions I ever saw in FLL used pneumatics. I don't know if you where around in 2002, but in the challenge that year there was a bridge on one side that was about one third as long as the table It started up, but with by hitting a lever it would fall flat. Hidden behind that bridge was a windmill, and with the other things on the table, the easiest way to get to the windmill to push a lever, was to go over the bridge. The bridge was quite treacherous to navigate over, and a plunge off the side meant almost certain death for many FLL robots (lesson learned: ALWAYS PIN YOUR ROBOT TOGETHER!) So, one team, used the pnemautics to power a little cart that they sent over the bridge. It was genious! It required no additional weight on the robot, and if it fell off, you wouldn't accomplish that mission, but your robot was off doing other things, so why would you care? Now, the same thing can be accomplished mechanically. See this video for further information (it's in the part with the gate). Overall, using carts to accomplish tasks is very effecient way to handle things.
Unread 18-10-2006, 15:11
Dylan's Avatar
FRC Mentor
AKA: Dylan Stoll
Re: Pnuematics?
Do you mean they actually made a pneumatics system that functioned like a motor? I couldn't tell from the video.
Unread 19-10-2006, 15:50
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Pnuematics?
That cart looks to be powered by either a pullback motor or rubberband drive of some type.
During the Mission Mars challenge one mission required the delivery of a ball into a container so it could be launched "back to earth". Our team accomplished this by carrying the ball in a container with a pneumatic trap door type device that allowed the bottom to drop out and the ball to be fall through. The biggest issue I found with the pneumatics is that the piston, switch and tank all have to be placed on the robot and attatching the switch to a motor (if that is how you want to activate it) can be difficult if you want any other type of motorized device.
The various pullback motors on the other hand i have found to be very useful. They were far more useful before the rule that requires the robot to leave base before completeing missions, but with a bit of inovation they can still be quite handy.
Unread 20-10-2006, 17:10
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Pnuematics?
They are aloud but it would to hook the valve up to a motor and a wast of a motor
Unread 07-11-2006, 13:04
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: Pnuematics?
Originally Posted by Dylan
... I was wondering if pneumatics are allowed on the robot. The rules do say that there is no limit on non-electric components as long as they are in "factory condition", but it does not mention pneumatics.
Yes, pneumatics are allowed, as they are non-electric LEGO components.
One of the teams that I coach, Mindstorms Mayhem, used pneumatics to power the "dump mechanism" on a "dump truck" that they used in the 2005 "No Limits" challenge. To see video of this attachment in use, see the first video on the "Team Videos" page: http://www.mindstormsmayhem.org/team-videos.asp
The attachment in question is the "next-to-last" mission in the round. (FYI, the infamous "ball extractor" is also shown in the above video -- this was also the highest-scoring round at the 2005 World Festival, resulting in Mindstorms Mayhem being awarded the First Place Performance Award.)
In the video, you can also see one of the difficulties with the use of pneumatics -- since only three motors are permitted in FLL, there isn't a good way to have the pneumatic cylinders be charged by the robot without devoting the third motor to this use. The approach that Mindstorms Mayhem used was to have three pneumatic cylinders (lots of air) that were charged manually by the robot handler just prior to running the mission. If you watch the video carefully, you can see the robot handler pumping up the cylinders manually just before launching the "dump truck" on its mission. The main reason that it was decided to use the pneumatics for this mission is that the "dump truck" wasn't actually the robot -- the dump truck was powered by windup motors, and used the pneumatics for the dumping action. The dump truck was simply launched by the robot -- for that mission, the robot itself never actually left the base. This year's rules would not permit the specific approach that Mindstorms Mayhem used to solve that mission in 2005.
Other problems with the pneumatics include the fact that air leaks are very hard to track down and diagnose; the air cylinders are pretty large, and it takes a lot of air to move anything significant. That said, the pneumatics are good for some specialized tasks. The Mayhemers aren't currently planning to use pneumatics for any tasks this year, but haven't ruled it out, either...
Best Regards,
--ken
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 07-11-2006, 13:49
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Pnuematics?
They are allowed, but I don't believe they would be of much use. You end up needing one motor to provide pressure, and at least one motor to control a value. You have just used two of your three motors, and you probably could do the same thing with one motor that had some gear reductions.
Eric Haskins KC9JVH
pnuematics great_one411 Pneumatics 1 16-02-2003 11:50
Pnuematics Manual ark_1230 Pneumatics 2 09-09-2002 18:29
leaky pnuematics???? archiver 2001 1 24-06-2002 02:18
Pnuematics archiver 2001 4 23-06-2002 22:55
Pnuematics Travis Covington Pneumatics 2 22-01-2002 22:09
