Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-10-2006, 13:40
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Tempurature Sensor
I am working on a project and I want to use a tempurature sensor to measure the tempurature of a liquid. Does anyone have any recomendations? It can be analog or digital.
Unread 16-10-2006, 13:52
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Tempurature Sensor
I'm working on a project that involves the temperature detection of an engine control module for a major automobile manufacturer. Omega has one that we are using, is inexpensive, and fits our needs.
Good luck,
Andy Baker
Unread 16-10-2006, 14:14
Team 2021 Captain
AKA: Chris Davidson
Good luck,
Andy Baker
I like the idea of that but its more heavy duty than what I need. Something cheap, accurate, and will work in the range of 0-50C, and easy to work with.
Unread 16-10-2006, 14:17
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
A thermistor is a component whose resistance varies with it's temperature. If you're using a microcontroller you can measure the temperature using an analog input. To connect the thermistor to the controller you connect one end to +5V and the other end to a 220 ohm resistor. The second lead of the resistor goes to ground. The analog input gets connected to the node between the resistor and the thermistor. The circuit is called a voltage divider. There is a large selection of parts at digikey.com. Radio shack might sell them as well. Excuse the ascii diagram, but you get the idea.
[code]
+5V
o
[ ] thermistor
o-----o to analog input
> 220 ohm resistor
o
Ground
Unread 16-10-2006, 14:20
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I'm not totally sure what your application is, but if all you want to do is visually monitor the temperature, you might see if your school has any CBLs lying around that you can use. The CBL is a device that plugs into most any TI graphing calculator, and comes standard with sensors for light, voltage, and temperature. The nice thing about this is that it won't cost you anything, and the application for 83+/84+ is graphically very nice. In addition, it is capable of doing data logging over time. Also, I'm almost certain that the temperature probe is waterproof.
Alternatively, you might consider picking up one of these. Jameco carries them for $0.34 a piece. This has an analog output that you can feed into a robot controller, or just monitor with a voltmeter. Since it is just a TO-92 case (like a small transistor), you will need to find some way to electrically insulate it, to protect it from the liquid.
I suspect that you'll find either of these solutions to be much more cost-effective and easier to use than the product in Andy's link.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-10-2006, 15:20
Team 2021 Captain
AKA: Chris Davidson
Ill probably be interfacing it with a 2005 RC just for testing purposes before I have the rest done. Thanks for all of your input.
Unread 16-10-2006, 19:42
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Temperature Sensor
Just use a J, T, K, or S type thermocouple and a level converter IC.
The level converter can be found here. I suggest the LM135 in the TO-46 Package. This will allow you to read in temperatures of -50C to 150C off of one of your analog inputs.
The temperature is read off in kelvins, with zero kelvin being zero volts. Calibration routine found here.
I used a thermocouple/level converter for a science project back in 7th grade, these things work great and are very rugged. Simple circuitry too.
If you need help just let me know.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 16-10-2006, 23:46
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
For non critical applications with decent margins of error, the LM19 is pretty sufficient and pre-calibrated. Your only problem may be insulating it unless you can find the metal-can package of it so you can dip its "head" into the fluid, or drill a hole at the side of the fluid container to place it, ensuring that no fluid touches the electrical pins. Hopefully your fluid isn't charged too.. dunno if the metal case is grounded or not.
| jamesyong.net |
FVC2007, FTC2008
Unread 23-10-2006, 12:39
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
-Q
QFT
Thermocouples are accurate, easy to get and reliable.. for most of your stuff a thermocouple with an inamp works reall well.
Ultrasonic Sensor winners Programming 3 02-01-2006 20:55
yaw sensor CHSguard72 Electrical 1 06-02-2003 01:44
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
Sensor Q Brew Technical Discussion 2 10-02-2002 12:48
Sensor Oakridege_665 Technical Discussion 5 10-01-2002 16:53
