Go to Post Just because a robot looks good and just because it is very well made does not mean that students were not involved in creating it. - Ryan Dognaux [more]
Unread 16-10-2006, 16:20
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
making a bench top PSU with a old school PSU
I remember the thread on makign a bench top PSU with a computer PSU, and how you have to ground the green pin. Well wanted to make a PSU for myself and all I have is a really old mitac PSU. It has 2 sets of wires that go to the mother board. on is as follows (black, black, white, red, red, red) and the other is (orange, red, yellow, blueish turquoiusish, black, black). Anybody know what wire to ground, I tryed all of them but none work.
Unread 16-10-2006, 17:10
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: making a bench top PSU with a old school PSU
it sounds like an old psu (before atx) most old ones like that have either a switch on them or smaller wires that plug into the motheboard....if its the latter connecting 2 of them should turn it on. its been a while so im only 90% shur thats how they work. if you could take som pics of it that might help.
Unread 16-10-2006, 17:11
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Does it have a power switch hardwired to the powersupply (or some empty terminals)? (I don't mean the one on the back, beside the plug.) If so, it's likely an AT power supply, which means that there is no need to ground the +5VSB line (because it isn't there). Cross those, and hold them, and it will operate.
In any event, the connector you describe sounds like an AT.
Unread 16-10-2006, 17:26
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
To use an AT power supply just flip the switch(sometimes they are on the back i have a bunch of compaq like that) and connect to the power leads you want using the pinout from tristan
KK4KQO
http://voltair.us
Unread 16-10-2006, 19:24
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Hey hey guys watch it.... computer power supplies only made to handle resistive loads....
that means no inductive ones. i.e. brushed motors
To turn on an ATX power supply, simply short the PS_ON pin to any of the GND pins.... but this wierd one I don't know.
I suggest plugging the power supply in, put your multimeter on vdc, hold the black probe to ground and look through the pins with your red probe until you come to one floating at an unstable or strange voltage... then try grounding it with a resistor. If it goes right down, then you've found a floating control line.
The only problem you might have is if this one uses sourcing instead of sinking logic... but I don't think it would.
If you need any other help hit me up.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 16-10-2006, 19:45
Cuog's Avatar
AKA: Alex
FRC #0422
Very good point on the ATX PSUs but the old AT PSUs *usually* dont have logic circuits, they just supply as close to dteady voltage as possible.
KK4KQO
http://voltair.us
Unread 16-10-2006, 23:50
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
After so much speculation.. just drop us a pic of it, easier to make deductions
| jamesyong.net |
FVC2007, FTC2008
Unread 17-10-2006, 08:12
You also may want to consider that some supplies will not turn on without a minimum load. As stated above, these supplies do not play well with motors as loads. It is not so much the inductance as the stall current. A motor that is not moving is stalled and as such the current demand for many motors exceeds 30 amps when starting. Kit motors like the Chalupas and FP motors exceed 90 amps.
Unread 18-10-2006, 10:38
AKA: Alex
in other words.... DANGER WILL ROBINSON!!!!
Unread 18-10-2006, 23:26
deus ex programmeur
AKA: James Yong
FTC #0747
One way to run such motors safely is to throw in a relatively large wattage resistor of a certain amount of resistance calculated from your motor, to limit the inrush current. You should end up with a slow-starting motor.
| jamesyong.net |
FVC2007, FTC2008
Unread 19-10-2006, 00:16
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I will have a picture up in about a day or so. I am NOT using it to run a huge motor with, I have no idea where people got that idea from. Honestly I dont know who in their right mind would run a robot motor off a bench top power supply.
Unread 19-10-2006, 09:54
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Atx power supplies will normally shut down if you try and demand too much current from them, then you just unplug the power cord, and plug it back in and dont do what you just did agin lol.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
UTC: The perfect combination of old school mixed with the new Andy Grady Regional Competitions 16 13-03-2006 19:53
Old School NS Action JakeGallagher Chit-Chat 0 19-03-2005 18:00
Bench top CNC suggestions Andrew Schuetze General Forum 6 08-12-2004 22:48
QOTW 08-24-03: Old School JVN Rumor Mill 21 04-09-2003 17:26
Old school cartoon! Elgin Clock Chit-Chat 2 07-02-2002 06:22
