Go to Post Finish... what an interesting concept. I'm still hoping to do that to our 2003 bot. - Joshua May [more]
Unread 17-10-2006, 07:56
Re: RC Powered on 7.2v backup
Originally Posted by BrianBSL
I'd bet that if you put a 7.2V battery on the 12V terminals it will work. Haven't actually tried it, but I'm pretty sure there is nothing in there that runs on 12v and it is certainly not within dropout range of the regulator.
Brian,
The RC has a low voltage detector that shuts down the main outputs and engages the backup when the main input voltage falls below about 7.5 volts for a length of time. This is to insure that the 5 volt regulator has sufficient voltage to keep the main supply at 5 volts.
Camera not powered...? Total Meltdown Programming 7 14-01-2006 01:54
Pneumatic powered cannons. Ronald_raygun Pneumatics 10 06-12-2005 01:09
Air-powered motors Zing Rumor Mill 17 29-12-2003 14:19
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
