Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 18-10-2006, 20:04
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: 2007 Robot Controller
I agree that integrating the radio can be done- there's buttloads of space in that box- but I don't think it will be done. The modems we use are not strictly for FIRSTs use, and IFI would either need a special order for a card type mount, or integration onto a reletively cramped board- something that requires quite a bit of work for, as Billfred said, a low volume product. But it could be done.
In my opinion, the only changes to the brain will be a firmware update. They just replaced the PIC (Which is software- the chips are the same size- pin count etc. I believe), they have a nice supplementary income from broken serial connectors .
But, I would like to see the USB programming support. There isn't a computer that can be used for programming that doesn't have USB support- the only problem is the addition of even more control hardware. PIC's, pull-ups, etc.
-Sir Francis Bacon
-Albert Einstein
Unread 18-10-2006, 20:51
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Im willing to bet that the radio stuff will happen(tazlikesrobots has a nack for these things), also willing to bet that USB support will finally be added. . also going out on a limb and saying that the camera will be different/better(they show out of stock).
but hey what do I know.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 18-10-2006, 21:51
FRC #0306 (CRT)
Originally Posted by Tazlikesrobots
I heard that the new controller will have the capability of using USB joysticks, and the radio receiver may be internal.
The problem with USB joysticks is that, unless there is a clever way around it, the RC needs to be a USB host to communicate- and even worse, may have to store several drivers just to support a reasonable number of joysticks. Which is a far different hardware story than a usb slave, as implementing a USB programming port would mean. It's a nice idea, but it poses a very steep set of obstacles to climb.
I would go out on a limb and say that FIRST would likely have us hack a USB joystick to gameport before they got IFI to develop the support. Additionally, if you wanted to support easy potentiometer/switch interfaces that teams construct on their own, you'd need either some gameport "ports", or a seperate analog-USB dongle to mediate.
-Sir Francis Bacon
-Albert Einstein
Unread 18-10-2006, 22:16
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
This entire thread somehow seems very familiar. As far as the whole USB joystick interface question on the OI I believe the solution has been posted.
Unread 19-10-2006, 00:15
Gdeaver Gdeaver is online now
FRC #1640
IFI will probably never incorporate a radio into the RC because of FCC issues. They may incorporate a FCC precertified module with and external antenna. This would be a significant cost savings. I think ZIGBEE would be a good fit however the technology needs a little maturing. Actually the are some Zigbee modules that could replace the operator interface.
Unread 19-10-2006, 17:02
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
I don't really think that the radios will change... i'm not sure if i would like the radio to beinside the RC.. it seems like it wouldnt get reception, but if it does and it works consistantly then i would defiently prefer that. As far as USB programming Parallax has done it and I have a feeling that IFI is going to follow suit..
http://www.parallax.com/detail.asp?product_id=28850
Hopefully IFI will supprise us this year
Unread 19-10-2006, 17:12
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
It wouldn't surprise me if a new camera was included; I've heard online that CMU developed a new all-in-one package for the camera.
I would hate for the program port to be removed (remember, that's also how you connect other peripherals - eg, the 2005 power distribution board). I would much rather see them start packaging USB-Serial adaptors. Also, moving to USB means developing drivers for it. (Windows for IFI, Linux for us.)
What may be helpful to alleviate this problem is if there was a SoIP (Serial over IP) system available for FIRST teams. Meaning that a virtual serial port is available to software that is forwarded to a "serial server" that is actually connected. Developing the server software isn't bad, it's the client driver in Windows that presents problems.
Unread 19-10-2006, 18:04
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
The 2007 controller(s) might already be out there, I had a thought today that maybe radical but it can be substantiated.
What if they are having teams build multiple minitaure robots this year? See, IFI only has the mini-controller for sale right now, and they are a good bit cheaper than the old controllers. So what if they give every team 3 controllers? And every time a light on the field changes like they demoed in Atlanta, a different robot needs to be operated? Instead of having one complex robot, we get three simple robots. Two heads are better than one, and three just might be fun.
It's just a thought.
Unread 20-10-2006, 02:00
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
I'm not so sure going from serial to usb for the controller ports is all that great.
What if a team wanted to develop a custom controller? This year is a perfect example, many teams made custom controllers to control their shooters. If IFI did change the controller port to usb everyone could just about kiss the days of custom controllers good bye because teams would pretty much be limited to a list of controllers the OI supported. IMHO that takes some of the inventiveness out of FIRST.
I do remember there being a thread similar to this before last year's kick-off and people were saying much of the same things. When kick-off came around the only significant upgrade was the memory boost.
Team 1538 / The Holy Cows, 2005-2016
Unread 20-10-2006, 08:15
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I have always wanted to have about 3 small bots and have them work together. Being able to communicate with each other. Something like this would turn out pretty cool I think.
Unread 20-10-2006, 15:32
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
usb would be sweet
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 20-10-2006, 19:22
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Not just FCC - but import/export regulatory reasons for other countries as well (different frequency bands, etc).
In addition, any time they made a major change to the RC, it would need new FCC testing.
I think it is very unlikely that the radios would be integrated - not much to gain from doing it for quite a large development cost.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 21-10-2006, 11:21
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
I agree with you that the game ports need to stay on the OI, they are easy to use and custom controllers are easy.. I am reffering to the SERIAL port used for programming the robot. I think they should change that to USB.. not the Game Ports on the OI
Unread 21-10-2006, 12:25
foote stepped in
AKA: E. Foote
FRC #0868
actually, it'd be interesting to see a firewire interface for programming. as for the joysticks, i don't think they would go usb, simply because they'd be switching from a bunch of pins to 4 or 6 (well, 4 really)
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 21-10-2006, 12:59
FRC #0190
Huh? USB is serial data and has much more bandwidth than the analog and digital joystick ports. There's only 2 data lines there - and you aren't going to be able to use them as GPIO without some custom circuitry.
I wouldn't mind seeing USB for Joysticks with some GPIO (yes IO, to allow some feedback as well as input) and analog inputs for custom controls.
As far as programming via IEEE1394 - that wouldn't make much sense either as
a) you don't need nearly that much bandwidth
b) interfacing IEEE1394 to a PIC is much more complicated than USB (off-the-shelf USB to serial converter chips)
c) IEEE1394 isn't nearly as standard on PC's as USB
Without switching PIC chips, however, they would simply be adding a USB to Serial adapter on the RC - which is pretty much pointless except they have control over it for troubleshooting reasons. They could accomplish the same thing by keeping the serial port, allowing the flexability of using the serial port for other applications (IE. breaker panel, custom circuits), and shipping a USB to serial adapter to every team that they have tested and know works well with the RC.
Robot Controller NotaNerd Control System 6 04-11-2004 16:53
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
Robot Controller Josh Hambright Electrical 2 23-01-2003 13:36
Robot Controller srjjs Rules/Strategy 4 08-01-2003 19:08
Robot Controller archiver 2000 3 23-06-2002 22:54
