Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
Unread 20-10-2006, 12:28
crashoverride02 crashoverride02 is offline
None #0587
crashoverride02 is an unknown quantity at this point
Programming the vex microcontroller to respond to commands on the serial port
Right now I'm developing a robot to operate with a vex and a pc controlling the vex. How do I get the Vex to respond to the serial port commands? I've found the JVEX reference and that protocol information doesn't work for the online code nor the hex that they provide. Any advice?
Unread 20-10-2006, 14:17
None #0587
Re: Programming the vex microcontroller to respond to commands on the serial port
So Far I've gotten the robot to initialize and send back the DIN information in online mode
(Note decimal values)
Init: 15 15 8 64 184 4
Request DIN: 170 85 0 0 0 11 0 0
PIC18F8520 port mapping to VEX microcontroller module. Yuriy Programming 2 28-04-2006 13:11
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Programming Vex Starter Kit To Recieve From Serial Port firetrap FIRST Tech Challenge 0 26-09-2005 17:27
Serial Port Programming phrontist General Forum 1 07-02-2004 16:13
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
