Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 21-10-2006, 14:20
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Re: pic: 114 wheel concept....again.
Just out of curiosity, what made you pick a 7/8" width (as opposed to, say, an inch)? Are you incorporating this into another design?
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 21-10-2006, 14:28
CraigHickman
Posts: n/a
I picked this width because .5 is too small, and we used ecaxtly one, and it was too much... so I picked a medium.
Unread 21-10-2006, 14:46
REVving up for a new season
FRC #2848 (All-sparks)
I am interested to find out why .5 is too small? Traction is not affected by surface contact so is there another reason this width was too small? I would think making wheels as small as possible while still giving them strength enough to survive competition, would be the way to go.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 21-10-2006, 14:53
CraigHickman
Posts: n/a
.5 is too small due to the size between frame members. Once we reach that size, we have to do some of the fram machining at other locations, which makes it cost more, and makes us unable to do the work at our shop. Plus, it makes smaller bolts necessary for parts to hold together, which makes working it take more time then the 1 inch width.
Also personal preference. It just looks darned stylish.
pic: 114 wheel concept CraigHickman Technical Discussion 8 22-06-2006 14:24
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
pic: 114: Stripped! CraigHickman Robot Showcase 5 04-04-2006 23:49
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
