Hi, i'm from team 1719, and we used to have all the progams nessesary to load code onto the robot. however, the computer with these programs was disposed of. we really need a list of these programs, and a place where we can download each of them? does anyone know?
Re: Hex code loader for the robot!
The IFI Loader, available at: http://www.ifirobotics.com/rc.shtml#Programming The default code, located at the same place as above The Microchip MPLAB IDE, available here: http://www.microchip.com/stellent/id...ame =en019469 The Microchip C compiler, not available online unless you want the trial. For an explanation of why, just search the forums. Hope this helps! |
Thanks!
Also, beware that the latest version of the compiler is not compatible with one of the libraries in the default code, so even if you get the trial version of that, you won't be able to link your code into a .hex file. Instead, you need to install the compiler from the CD you got.
You also may want the IFI Dashboard program for help debugging. It is located at the same place as the Loader and default code (http://www.ifirobotics.com/rc.shtml#Programming)
| IFI Loader doesnt open .hex file | travmizer | Programming | 10 | 02-10-2006 20:45 |
| pic: The whole robot (Without pneumatic loader or hopper) | imax48236 | Robot Showcase | 8 | 14-02-2006 10:48 |
| problem loading code with ifi loader | psych0gambit | Programming | 7 | 25-02-2005 20:43 |
| Ruling for what defines being at the auto-loader | Andrew Schuetze | Rules/Strategy | 4 | 15-01-2005 22:41 |
| IFI Loader problem - "Invalid HEX file" | wun | Programming | 9 | 22-09-2004 12:35 |
