Go to Post I wasn't pouting; just cowering in fear because I actually thought you were mad at me... I didn't want a clipboard to the head like Billfred here. - Jon K. [more]
Go Back   Chief Delphi > Other > VEX
Unread 22-10-2006, 19:52
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Exiting Autonomous Mode
I wrote some code using the 2006-2007 Competition Template.
The code never exits the Autonomous function to transfer to the manual operation.
Is anyone else having this problem? If so, have you figured out what is wrong?
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 23-10-2006, 10:00
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Exiting Autonomous Mode
Have you updated the Master Code to version 7? If not, here's the download link for that:
http://www.vexrobotics.com/docs/soft...-master-v7.zip
Also, make sure you do not have a jumper clip on interrupt 5 - that makes it so it will only run autonomous. A jumper on interrupt 6 forces it to run only the operator control portion, so you could place one there and see if it's a code problem or not.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 23-10-2006, 10:46
No jumpers in place at all and I'm running V7.
I updated my V2 copy of Easy C last night, but haven't reloaded code yet.
I doubt that that is the problem, but I'll find out this afternoon.
Warren B
Unread 24-10-2006, 07:39
No luck with the upgrade. Still not getting to the Manual operation section of my code. What a VEXing problem......
Warren B
Unread 24-10-2006, 13:33
MattD's Avatar
Hmm. Other than the transmitter not having the Drive mode set to 23, I can't think of anything else.
- Turn the transmitter on and hold down the Mode and Select buttons located next to the display until the menu is opened.
- Press the Mode button until "DRIVE" is displayed.
- Use the +/- buttons to set the Drive mode to 23.
If that doesn't work, could you show the code?
Unread 25-10-2006, 12:34
I've got this to barebones.
Open the competition template.
Open the Autonomous block and put in a Print-To-Screen
Open the Operator block and put in a P-T-S
Build & Download
Open the Terminal window
Turn on the transmitter
Let me know what you see after 20 seconds.
Warren B
Unread 30-10-2006, 13:39
And the real solution is........
Download the correct version of the Master Code!!!!!
There are two version of Master Code V7. One for EasyC and one for MPLAB.
Make sure you download the correct one.
Thanks go out to Rick Torrance for pointing this out to me and being so patient with me in the process.
Warren B
Autonomous mode Tyler Olds General Forum 30 22-02-2004 14:31
Autonomous Mode tysonwormus Rumor Mill 11 08-01-2004 22:59
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
Autonomous Mode David Bryan Programming 1 21-01-2003 21:15
