Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 23-10-2006, 21:34
nelsonabo nelsonabo is offline
nelsonabo is an unknown quantity at this point
Autonomous play question
If you are not allowed to touch the robot, how do the robots get started during autonomous mode? Once turned on, won't they run their program right away?
Unread 23-10-2006, 22:59
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: Autonomous play question
All robots are programmed with either easyC using a competition template, or the specialised MPLAB code. Either option has code running in the background that will not run your code until your controls are turned on. At the field, you will plug the controls into the filed control system. The system will only allow the controls to send out a signal once the match has started.
To make your robot work, make ABSOLUTLY sure that you either use the templates in easyC or use the default MPLAB code which can be found on vexlabs.com . If you have any more questions, do not hesitate to ask .
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Autonomous Question..... slickguy2007 General Forum 5 09-02-2005 23:04
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Autonomous testing question tml240 Programming 8 24-02-2004 16:12
Newbie Autonomous Question(s) Paradox1350 Programming 21 16-02-2004 13:47
