Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 24-10-2006, 18:38
Musician's Avatar
Musician Musician is offline
Mechanical/Electrical/Driver/Music
AKA: Cody
FRC #0339 (Rappahannock Robotics)
Musician is an unknown quantity at this point
Help w/ PHP
Hey, I'm an amateur webmaster. Can anyone give some advice with implementing PHP and MySQL with the following website: http://205.174.115.19/
2006 - Semi-Finalist at the Chesapeake Regional
2005 - Quarter-Finalist at the Duel on the Delaware
2005 - 1st seed at the Duel on the Delaware
2005 - Semi-Finalist at the Capital Clash part of the Digital Expo in D.C.
2005 - Finalist at the NASA/VCU Regional
2004 - Quarter-Finalist at the NASA/VCU Regional
2004 - Motorola Quality Award at the NASA/VCU Regional
2003 - Featured on the Discovery Science Channel
2003 - General Motors Industrial Design Award
2002 - Winner of the Johnson & Johnson Mid-Atlantic Regional
2001 - Xerox Creativity Award
Unread 24-10-2006, 19:14
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Help w/ PHP
There are two easy things you can do to that page using PHP:
Right now, you are calling separate HTML files inside of a frame in order to create sub-pages. Instead of that, you could just write up your page template as separate file and simply have PHP automatically stick that header and footer into every single one of your pages. Then each individual page's code will look like:
PHP Code:
include("header.php");
p>Oh manwhat a cool page I have!</p>
include(
"footer.php");
Header.php and footer.php will contain all the boring HTML markup that is the same on every page, freeing up each file to just be the relevant code for that area. You can google around a bit to find some more information on these techniques, and I highly recommend taking advantage of the php.net website, which lets you search for information about almost anything you would ever want to know about PHP commands and syntax.
If you get comfortable with that, you can get really fancy and build a membership system. This phpfreaks.com tutorial is what taught me how to create login systems that I have since used on a few of my own projects. It's extremely step by step, but by the end you should have a solid understanding of what each piece of the system is doing when a user logs in.
You could use a user login system to protect sensitive documents, set up some sort of communication system, or just to be cool-looking.
Good luck! PHP is some pretty amazing stuff.
Unread 24-10-2006, 19:56
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Help w/ PHP
Is there something specific you want to do? If so I can help you. What where you planning on using MySQL for?
Unread 24-10-2006, 22:20
GRaduns340 GRaduns340 is offline
The Fruit Man
AKA: Gary
FRC #0340 (Greater Rochester Robotics)
GRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura about
Send a message via AIM to GRaduns340
Re: Help w/ PHP
The suggestion about include statements is definitely a good start, but once you get comfortable with that, you might want to move into storing content for each page in a database, then use a PHP to print the page's content from the database rather than from each file. That way you have ONE page with all of the relevent header and footer for every page, and the database holds unique entries for each of the others. It also saves a lot of space and effort. If you decide to add another section in addition to header/footer (or whatever you have) you can easily go back and change it once, rather than have to add it to every file again, which was the idea to avoid in the first place.
Unread 25-10-2006, 20:48
RoboJedi75's Avatar
RoboJedi75 RoboJedi75 is offline
Do or do not, there is no try.
AKA: Nate Fong
FRC #0075 (RoboRaiders)
RoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura about
Send a message via AIM to RoboJedi75 Send a message via Yahoo to RoboJedi75
Re: Help w/ PHP
Another option if you have a lot of pages: you can create the basic layout page (the header and the footer) and replace the body content with this code:
PHP Code:
if($_GET['page'] == "") {
    include(
"includes/main.php");
} else if (!
file_exists("includes/".$_GET['page'].".php")) {
    echo
"Page not found.";
} else {
    include(
"includes/".$_GET['page'].".php");
This code just checks that a body content file exists and then loads it. Navigation is done by index.php?page=home. If no extenstion is given, then it loads main.php.
It's simple and I've seen a lot of websites use this method.
Nate Fong
Team #75, the RoboRaiders, Alumni
Unread 25-10-2006, 22:19
The Fruit Man
AKA: Gary
Re: Help w/ PHP
PHP Code:
    include(
} else if (!
    echo
"Page not found.";
} else {
    include(
That's probably a better idea than I suggested. I guess I just overthought it. I've used that method, too, and it is certainly simple enough to pull off.
php/forms/posting/I NEED HELP!!!!!!!!! general Programming 69 29-03-2006 14:36
php/forms/posting/I NEED HELP!!!!!!!!! general Website Design/Showcase 5 21-03-2006 16:36
PHP Help FRANK(WGH) Website Design/Showcase 5 22-02-2006 22:06
PHP Coding HELP!!! FRANK(WGH) Website Design/Showcase 9 26-01-2005 17:18
PHP bb... Stefan Website Design/Showcase 3 31-07-2003 13:48
