Go to Post I hope there are people in this world who love you too much to let you mentor while you are in college - PayneTrain [more]
Unread 25-10-2006, 02:42
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Help needed timing a pulse (2004 Robovation)
Originally Posted by Josh Siegel
how I can convert the values into a usable time (mS, uS) that may be accessed like a variable.
How does Kevin Watson do this in his infrared receiver code? It looked like he might have some usable way of measuring a pulse width.
That's exactly what I would look at. Kevin Watson's IR receiver code. Specifically the routines for identifying which of the two beacons is being detected. They each produced a different pulse width signal.
In a nutshell:
Set up a timer to increment at whatever resolution you need measure your pulse width at.
Start timer.
Interrupt on each falling edge (or rising, or both depending on what you want).
Service the interrupt by checking your timer variable, and reset your timer variable to 0.
Lather, Rinse, Repeat...
For interrupts, this is a pretty good first project. Just be sure to disable your interrupts temporarily when you modify variables that are modified by other interrupt service routines. In the above example, you'll want to disable interrupts whenever you increment or reset your timer variable, then re-enable them right after.
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
robovation KIT help Mirza95vx Technical Discussion 2 03-12-2004 15:08
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
PUlse counting junkyarddawg Technical Discussion 1 31-01-2002 15:33
