Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 25-10-2006, 14:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Help needed timing a pulse (2004 Robovation)
Originally Posted by yongkimleng
May I ask, is there a possibility where during the copy of the first 8 bits, the value is something like 255, and when it proceeds to copy the next 8 its, it increments by 1 (due to the overflow of the first 8 bits when the timer ticks a few more times) before it gets copied, resulting in a larger value than expected?..
That would be why you'd prefer having the timer in 16-bit read mode. In this mode, when TMRxL is read, TMRxH is instantly copied to a buffer, which can be read without fear of this problem. Writing is reversed. you write to TMRxH, which is stored to a buffer, then wrtie to TMRxL, which write that value and copies the buffer to the timer at the exact same time.
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
robovation KIT help Mirza95vx Technical Discussion 2 03-12-2004 15:08
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
PUlse counting junkyarddawg Technical Discussion 1 31-01-2002 15:33
