Go to Post Before you fix something, it's worthwhile to make a concerted effort to figure out why it failed. - Ether [more]
Unread 24-10-2006, 22:21
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Re: Hovercraft?
Originally Posted by efoote868
well, don't 6-wheel designs tilt somewhat too (with the "dipped" wheels)?
and, for that matter, any bot with center of gravity issues is likely to tilt/fall over too.
Who knows, maybe it'll be a water game, and hovercrafts will be all the rage
The difference between tilting a bit, and tilting as much as 60-70 degrees
edit: DO I HEAR ROBOTIC WATER POLO?!?!?!
I will not leave my account logged on to chiefdelphi again.
Unread 24-10-2006, 22:31
foote stepped in
AKA: E. Foote
FRC #0868
Re: Hovercraft?
lol.
60-70 degrees? thats not even possible
If the air bubble you're riding on is low enough to the ground, it shouldn't be that much of a problem. A hovercraft is still a hovercraft if you're floating 1/32 in off the ground, or 20 feet off the ground. The less you're off the ground, the less you can (really) tilt.
Besides, if someone pushes you, you won't really tilt, as much as float away..............
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 24-10-2006, 23:20
Crimson Ninja
AKA: Pat
Re: Hovercraft?
lol.
Unless you're deflating and inflating skirts, which will naturally induce tilt. Though depending on your height, 60-70 degrees is quite impossible or possible I was thinking about a robot higher off the ground than I realized at the time would be practical.
Unread 25-10-2006, 19:35
MrBlack298's Avatar
MrBlack298 MrBlack298 is offline
Everyone wants to be Mr. Black...
AKA: Jack
FRC #0177 (Bobcats)
MrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura about
Re: Hovercraft?
But you guys are all forgetting, this year is going to be a water game
In all seriousness, as cool as a hovercarft would be, the robot's pushing power would be so impaired that you couldn't go through with the design- competitively. But, it would be awesome enough that doing well with it wouldn't matter
Triple Threat!!!
You should listen to The Monotones
Unread 25-10-2006, 19:46
foote stepped in
AKA: E. Foote
FRC #0868
Re: Hovercraft?
haha, it probably would "inspire" a new award, or at least automatically get the Xerox Creativity Award.
Hovercraft edomus General Forum 24 02-06-2005 21:00
pic: Hovercraft edomus Extra Discussion 11 01-06-2005 11:55
