Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 25-10-2006, 17:21
xtolbert_gators xtolbert_gators is offline
FRC #1250
xtolbert_gators is an unknown quantity at this point
Victor Brakes
How do u hook a victor up so that you can reverse the polarity and cause the motors to stop. Could this cause a type of brake?Could there be a way to include it into the programming so that we can control it from the control board?
Unread 25-10-2006, 20:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Victor Brakes
All Victors except the SC (Spin Control) versions are capable of running motors forward and reverse. PWM values* of 128-254 run a motor forward, values of 126-0 run the motor in reverse. Yes, running a motor in the opposite direction that it's turning will rapidly stop the motor. Of course it won't just stop at zero speed, it'll start turning in the opposite direction unless you put it in neutral.
Also, if a motor is turning full power full speed in one direction, and you instantly change it to full power in the opposite direction, you run a good chance of blowing a fuse or breaker somewhere. This draws a LOT of current.
*There's a deadband of 12 or so around 127 where it's still in neutral, but I can't remember the exact size. It's probably actually 134-254 and 122-0.
Unread 25-10-2006, 20:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Victor Brakes
Also, the Victors have a Brake/Coast jumper (check the manual) when this jumper is set to Brake and the victor is in the neutral range, it will short the leads of the motor causing a resistance to motion. I believe you can somehow hook the brake coast jumper pins to the robot controller to have selectable braking.
Unread 25-10-2006, 20:20
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Victor Brakes
Yes, you can. Simply switch some of the digital inputs to digital outputs, and you're good to go. Just drive the pins.
-Sir Francis Bacon
-Albert Einstein
Unread 25-10-2006, 20:22
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Victor Brakes
I believe there is something in the rules against this though... let me check.
Nope, guess I was remembering something else... but anyway... check this thread out?
http://www.chiefdelphi.com/forums/sh...906#post449906
Unread 25-10-2006, 20:23
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Victor Brakes
It should also be noted that there is a function called dynamic braking, in which the Victor shorts it's output creating a short across the motor windings. This causes drag on the motor that is proportional to the speed in which it is spinning. It only engages when the Victor receives a neutral signal.
It is controlled by a jumper setting, and there is round about method of remotely turning this on and off. It can't hold a motor stopped on it's own, but it will slow down a free spinning motor. Some teams use dynamic braking on the victors that control their main drive motors. It has the effect of eliminating any coasting a robot might otherwise have. Most teams, however, do not use dynamic brakes, feeling that the sudden stops produce more strain on the drive train and victors then is worth it. More common uses are for motors controlling long arms that otherwise 'droop' when no power is applied.
Could you describe what you want a brake for?
Edit- The method that I know of for remotely turning the dynamic brake on and off is to wire the jumper pins to a limit switch, and toggling the switch with a servo (or other mechanism). I don't know exactly how the pins function, so I couldn't say what the result of applying voltage from a digital out might be. Can you simply cause digital out to create a short? If so, that would be a much simpler way of doing it, although possibly illegal.
-Andy A.
Unread 25-10-2006, 20:47
Re: Victor Brakes
That would have been illegal under last year's rules I believe.
Unread 25-10-2006, 20:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Victor Brakes
This site shows how to control the brake/coast setting from the RC.
http://www.ifirobotics.com/forum/vie...956098 63b6c6
Eric Haskins KC9JVH
Unread 25-10-2006, 21:18
Re: Victor Brakes
It's also important to note that the retarding torque provided by dynamic braking is directly proportional to the speed the motor is rotating at.
Trick Question: Assume a frictionless CIM motor, with some internal resistance, spinning at, oh, 100 rpm. When does it stop spinning if you turn on dynamic braking? The answer should tell you why dynamic braking isn't necessarily useful.
Unread 25-10-2006, 21:38
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Lightbulb Re: Victor Brakes
I don't know if this thought will help, but what about regenerative braking?
I figure(correct me if you see errors), put a single-pole, double throw contact switch between motor, victor and leads to diodes then to a battery. By switching to the leads with diodes the motors are turned into generators by the forward motion of the robot. The diodes are so the battery doesn't back into the motors causing them to run at full.
Eat, Sleep, Build Robots
Unread 25-10-2006, 23:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Victor Brakes
Sounds interesting, but also illegal under 2006 rules. Per <R59>, custom circuits may not "[d]irectly alter the power pathways between the battery, fuse blocks, speed controller/relay, and motor." (Excepting voltage- and current-measuring devices.)
Per <R70>, "[d]igital outputs of the Robot Controller may be connected directly to brake/coast headers on the speed controllers to permits [sic] programmable control of this speed controller function. The brake/coast header on the speed controller may NOT be connected to any other circuit or input."
Unread 25-10-2006, 23:32
AKA: Dr. Brooks
no team (WRRF)
Re: Victor Brakes
I think that the intent of the rule here is to be using a relay
to replace the jumper, and control the relay with the RC.
Unread 25-10-2006, 23:51
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Victor Brakes
I don't think you need the switch. There's some diodes in the transistors that will do the job. If all of the transistors are off, spinning the motors forces current into the supply.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 25-10-2006, 23:53
Re: Victor Brakes
Originally Posted by eugenebrooks
I think that the intent of the rule here is to be using a relay to replace the jumper, and control the relay with the RC.
IFI actually approves of the direct method, with one conductor betwen the signal pin on a digital output and the centre pin on a Victor, without any intervening circuitry. It's just a matter of feeding the B (centre) pin a high or low signal for coast or brake, respectively—and the A and C pins on the Victor just happen to correspond to those levels when using a jumper. See here for some more information.
As far as I know, this rule was uniformly interpreted as written during 2006 inspections, meaning that the use of a Spike or other relay to trigger the brake/coast settings would not have been permitted.
Unread 26-10-2006, 08:18
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: Victor Brakes
IFI actually approves of the direct method.. See here for some more information...As far as I know, this rule was uniformly interpreted as written during 2006 inspections, meaning that the use of a Spike or other relay to trigger the brake/coast settings would not have been permitted.
I agree with Tristan. We researched this last year, and found the same postings he notes. We were surprised that IFI did not recommend a method similar to what Sciguy and EugeneBrooks suggested. At the Palmetto Regional, we built and successfully tested a wiring harness to switch our drive train Vics between Brake/Coast modes, from the Digital I/O pins of the FRC. Afterwards we decided not to use it in the competition, since it did not provide the type of braking effect we were looking for.
Eric
Don't PANIC!
S. P. A. M.
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
Plants in my Victor? Rickertsen2 Electrical 1 23-10-2005 20:47
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Victor problems quickie25 General Forum 2 18-02-2004 19:51
