Go to Post Gracious professionalism is a two-way street. - Bharat Nain [more]
Unread 25-10-2006, 21:44
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Re: Chain drive vs. togged belt drive
Originally Posted by LordBritten
Has anyone tried togged belts instead of chain?
Any ideas?
Any comments about the idea?
Do you mean cogged belts?
If so then according to Goodyear "Because of their higher coefficient of friction, cogged belts tend to be more sensitive to alignment. While envelope belts can tolerate some misalignment, cogged belts are more likely to turn over under the same conditions. Cogged belts should not be used in clutching drives, drives with severe shock loads, and drives that have changing center distances, such as shaker screens. In these applications, the aggressive nature and flexibility of cogged belts can cause vibration, belt turnover, and belt breakage. Cogged belts should also be avoided in drives that require slippage during frequent stops and starts."
Timing Belt Drive System maclaren Technical Discussion 31 01-08-2006 10:08
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
belt drive/tank treads dradius Kit & Additional Hardware 14 19-06-2005 23:16
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
