Go to Post You know this crazy ChiefDelphi... nothing but useless information and kids ranting about pizza. - Amanda Morrison [more]
Unread 25-10-2006, 21:39
LordBritten's Avatar
LordBritten LordBritten is offline
Lord Britten strikes again!!!!
AKA: Matt Britten
FRC #0949 (Wolverin Robotics)
Team Role: Driver
LordBritten is an unknown quantity at this point
Exclamation Chain drive vs. cogged belt drive(timing belts)
Has anyone tried cogged belts (timing belts) instead of chain?
Any ideas?
Any comments about the idea?
Unread 25-10-2006, 21:44
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Re: Chain drive vs. togged belt drive
Originally Posted by LordBritten
Has anyone tried togged belts instead of chain?
Any ideas?
Do you mean cogged belts?
If so then according to Goodyear "Because of their higher coefficient of friction, cogged belts tend to be more sensitive to alignment. While envelope belts can tolerate some misalignment, cogged belts are more likely to turn over under the same conditions. Cogged belts should not be used in clutching drives, drives with severe shock loads, and drives that have changing center distances, such as shaker screens. In these applications, the aggressive nature and flexibility of cogged belts can cause vibration, belt turnover, and belt breakage. Cogged belts should also be avoided in drives that require slippage during frequent stops and starts."
Unread 25-10-2006, 21:52
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I've never used timing belts (cog belts) on a first machine before, but use em a lot around work. They work very well for high transmission energy, minimal backlash, high accuracy situations. Have a linear positioning table using a large timing belt drive (4 leadscrews driven by 1 step motor), whole system is accurate to +/-0.0005" with up to 600lbs on it
cog belts work awesome for high precision/high torque applications, just make sure you do your math right and line everything up, and keep at least a few teeth engaged in each pulley to prevent skipping teeth.
if any ?'s hit me up.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 25-10-2006, 21:57
Billfred's Avatar
Billfred Billfred is offline
Re: Chain drive vs. cogged belt drive(timing belts)
1293 used timing belt on their elevator lift in 2005. The lift was smooth as anything--it was beautiful stuff.
Unread 25-10-2006, 22:02
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We don't use timing belts for the drive because of slippage that might occur. Plus there's the fact that there is no way to alter the length of a belt and they are a hassle to put on.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 25-10-2006, 22:10
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
We hope to use them next year, At least from the motor to the first drive wheel. They have been more reliable for us than chain, and I still love taper-lock But we'll really just have to wait and take a look at next years game to see ...
Unread 25-10-2006, 22:25
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
we used 2 for our ball collector this year... it seemed like a good idea at the time.
What it really amounted to was frustration everytime we took the darn thing apart, and now in the offseason, (probably because we 'over-tweaked' the robot) when we go to give demonstrations, and we pick up balls, the collector actually stops once the ball gets in it , then the ball slowly crawls up and in. (not saying it will happen to you, but be wary)
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 25-10-2006, 22:32
AKA: Matt Britten
Team Role: Driver
well we used the timing belts for our ball collector and it worked fine but the chain for our drive train would break all of the time and we thought that we might want to use the cogged belts next year.
Unread 26-10-2006, 01:29
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
This year probably saw more teams using timing belts for the synchronous belt pulley on the large CIM. They are a whole lot quieter, but for adjustability in length I'll use chains.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 26-10-2006, 01:38
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Both of them have their pros and cons
Cogged belts can beat chain in lighter weight, and chain can beat it in high torque transfer such as in a really torquey drivetrain. A timing belt is pretty reliable for transferring lots of torque, but there is the chance you could rip it in a worst case scenario, which could be avoided by a good design. Though like Gabe said, you have to get your design down first before ordering belts, because you can't change its length quickly like you can with chain by just popping out a link or two.
If you design it well, it will perform well.
Also, both chain and belts will stretch, so you need someway to tension it. If you just keep it static, then as it stretches, problems will arise of the belt or chain popping off and it failing.
Good luck with your designs though.
Also Lord Britten, what pitch of chain did you use? #25 or #35?
Unread 26-10-2006, 08:04
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
for our shooter we hooked up the large sime via a small cogged belt. it worked beautifully and we had only one problem. the belt semi wore out through the course of 1.5 competitions and needed to be replaced. we expected this so we were able to easily disassemble and replace the belt no prob.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 26-10-2006, 10:42
When half of your robot gets bashed in during a match, you'll be happy you used #35 chain.
Unread 26-10-2006, 17:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Okay, with the 2003 robot, "The Raging Squid," Team Fusion used belt drive. The advantages to belt drives are weight and responsiveness (lack of slack like with chains). However... the belt drive slips so much that there is no way that it could compete with our 2005 or 2006 robot in a pushing contest. As with chain, you usually don't have to worry about slippage or it snapping like with belts, but of course with chain, you must use metal sprockets and the metal chain weight quite a bit. We use #25 chain for our robots to cut the weight and we have not had any of our chains break in the past 2 year.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 28-10-2006, 13:42
AKA: Matt Britten
Team Role: Driver
#25
Unread 28-10-2006, 13:45
AKA: Matt Britten
Team Role: Driver
Mt team used #25 chain last year and our chains would break all of the time. that is why lost in the semi-finals at the Portland regional we did not have time to fix the chain.
Timing Belt Drive System maclaren Technical Discussion 31 01-08-2006 10:08
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
belt drive/tank treads dradius Kit & Additional Hardware 14 19-06-2005 23:16
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
