Go to Post Teams whose goal is to play on Einstein think about strategy differently from teams whose goal is to be selected for an alliance at a district event. - alopex_rex [more]
Unread 29-10-2006, 09:38
in between teams
AKA: Luke Van Oort
Re: 80/20 frame Material Questions
Originally Posted by Hachiban VIII
80/20 is also difficult to cut. I would not recommend using it unless you have access to a mill. Cutting 80/20 on a band-saw or with hack saws will leave rounded ends, making butt-joints impossible. Without secure joints your whole frame will warp.
Last year we used 80/20 for our superstructure, and we found that a miter saw with a wood blade worked fine for straight cuts on a budget. (Aluminum seems to be soft enough not to cause trouble with the wood blade)
Team 1219: 2009 - Mentor
Best frame building material superbeano2004 Technical Discussion 59 29-04-2005 08:43
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Frame Dragging Wetzel Math and Science 0 22-10-2004 17:10
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
frame material survey punarhero Technical Discussion 12 21-02-2002 06:47
