Re: Need help with stereo switch box
you should just have to connect the right and left wires to the switch and connect all of the grounds together. by phono plugs do you mean RCA or 1/8th inch? if RCA the part around the center plug(the bigger circle is common and the center gets connected to the switch.
yeah that should work......I've done some custom audio stuff......i would have made a mixer but i didn't have any audio potentiometers so it sounded horrible....
let us know how it goes and if you have any questions just ask.... /forest |
Simon,
Normally a two pole switch will work but you might want to consider double throw switches so that the inputs are switched into 10,000 ohm resistors when they are off line. The resistors will help in charging the output capacitors in each source device you have connected. Without resistors you might experience a slight pop when switching between inputs. Take a look at the MCM catalog http://www.mcmelectronics.com/ A #50-5725 Six input Stereo Line Level Source Selector is likely what you are looking for at $57.70. Less expensive but with top mounted switch is #50-5180 at $16.50. VIDEO SELECTOR 6-INPUT 2-OUT L/R AUDIO S-VIDEO #50-7780 will give you added ability to switch video as well at $37.89. |
| Need Help Wiring Micro Switch/Limiting Switch | Windward | Electrical | 2 | 07-02-2006 18:26 |
| Need a little help with how to break out of the box | amateurrobotguy | Programming | 6 | 16-01-2006 12:56 |
| Need help with gear box bearings | JIN | General Forum | 9 | 21-03-2005 20:10 |
| Need help with gear box bearings | JIN | Kit & Additional Hardware | 1 | 21-03-2005 12:46 |
| NEED HELP with Delay loop for compressor relay switch | archiver | 2001 | 10 | 24-06-2002 02:11 |
