Go to Post What I want is to ultimately make it so that the programming is actually done before the robot is finished. Imagine that! - Danny Diaz [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 26-10-2006, 00:04
tyguy2021's Avatar
tyguy2021 tyguy2021 is offline
FRC #1839 (TechAttack)
Team Role: Webmaster
tyguy2021 will become famous soon enoughtyguy2021 will become famous soon enough
Popup Menu Help (dreamweaver)
On my page I have two div layers. One of them includes a image, the other a button that brings up a menu.
When the menu comes up it goes behind the other layer.
The popup menu is on a higher layer than the image and you can see the text when it is highlighted.
Anyone know how to fix this?
Unread 26-10-2006, 08:58
RoboJedi75's Avatar
RoboJedi75 RoboJedi75 is offline
Do or do not, there is no try.
AKA: Nate Fong
FRC #0075 (RoboRaiders)
RoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura about
Send a message via AIM to RoboJedi75 Send a message via Yahoo to RoboJedi75
Re: Popup Menu Help (dreamweaver)
what's your code?
Nate Fong
Team #75, the RoboRaiders, Alumni
Unread 26-10-2006, 14:52
GRaduns340 GRaduns340 is offline
The Fruit Man
AKA: Gary
FRC #0340 (Greater Rochester Robotics)
GRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura about
Send a message via AIM to GRaduns340
My guess (without looking at the site) would be that you used absolute positioning, and that the div your menu is hidden behind is also absolutely positioned. If that's the case, I think the issue is in IE's rendering of the page, and it should load right in a few other browsers, but I would still try to fix it. I'm not sure if that's right, but I remember reviewing a site with that problem and it worked in one and not the other. Try to see if there's a way you can either use a z-index or get rid of the absolute positions.
Unread 29-10-2006, 19:54
tyguy2021's Avatar
Yes I did use absolute postioning, the weird thing is you can see the text but not the box.
And I have tried it of 3 differn't browsers and 2 differn't operating sysems and it does it on all of them.
Team 1839
2006 Rookie inspration award
2006 Rookie highest seeded award
portland regional
Unread 29-10-2006, 21:33
The Fruit Man
AKA: Gary
If you post or PM a link to the site I'll see if I get a chance to take a look at it this week. It's a busy week for me, but I can try to take a peak sometime.
Drop-Down Menu help Rez648 Website Design/Showcase 6 09-02-2005 13:11
Java Drop Down Menu Help KTorak Website Design/Showcase 4 06-02-2005 20:59
Questions about Dreamweaver... Rez648 Website Design/Showcase 10 01-06-2004 14:13
Popup for new PMs? Billfred CD Forum Support 2 18-05-2004 17:22
DHTML Menu Help DCA Fan Website Design/Showcase 2 09-10-2003 02:08
