Go to Post Sometimes the team really needs the kid, and sometimes the kid really needs the team. - Taylor [more]
Unread 30-10-2006, 19:19
Re: What type of drive train is the most maneuverable?
Originally Posted by efoote868
...We also found out that a gyro is affected by temperature, pressure, etc. greatly; and that it gave out different readings at different times of the day ...
if that was true then your gyro was defective or there was a bug in your code reading the gryo value. Solid state gyros are highly reliable, the same AD chips used on the robots are used in cars for things like airbags and stability control (steering).
One thing about the gyros, they must be solidly mounted to the chassis of the robot. If the gyro can wiggle and vibrate (if you hold it down with tie wraps, or foam tape) you will get all sorts junk on the output signal.
To be useful the gyro chip must move exactly the same as the robot chassis moves.
what type of shooter will be most common this year? gondorf Technical Discussion 16 16-01-2006 17:05
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
What will be the most effective robot type this year Rick General Forum 8 13-01-2002 22:10
