Go to Post Maybe we'll see some awesome Game change like.... CARPET! - thefro526 [more]
  #31   Spotlight this post!
Unread 30-10-2006, 18:11
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: What type of drive train is the most maneuverable?
Originally Posted by Jonathan Norris
I would totaly agree that a 6-wheel drive system would be ideal,... Have a look at a team like 1305 from this year for a sweet 6-wheel drive system.
A look at 610 from this year would be worthwhile, too. Very nice use of 6WD and grippy stuff on the wheels.
Richard Wallace
since 2003
  #32   Spotlight this post!
Unread 30-10-2006, 18:23
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
For a defensive/offensive combo, Swerve would be the cream of the crop, but also expensive. The "best buy" for an agile defender would probably be a 6WD.
  #33   Spotlight this post!
Unread 30-10-2006, 18:26
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by Veselin Kolev
...And they're arguably more complicated to program, needs sensors, etc....
Our programmers this year actually got the code down to 4 lines... and it was just converting joy numbers to good PWM values.... super efficient.
Most programmers that I've met actually say they're easier to program than a 4-wheel / 6 wheel tank drive, or at least the ones that have used them.
Only a very weird configuration would make it harder... like only using 3 wheels
As for making it go relative to the driver, thats where it becomes tricky (all that great vector math). Thats where we used the gyro, and thats how our robot messed up (preseason, the lead programmer then decided that it wasn't worth our time).
We also found out that a gyro is affected by temperature, pressure, etc. greatly; and that it gave out different readings at different times of the day oh well
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #34   Spotlight this post!
Unread 30-10-2006, 18:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How would vectors not apply for robot-centric control as well?
  #35   Spotlight this post!
Unread 30-10-2006, 18:40
Aaron D. Aaron D. is offline
AKA: A-ron
FRC #0341 (Miss Daisy)
Aaron D. is on a distinguished road
Send a message via AIM to Aaron D.
I'm simple. I am a fan of the 4w tank drive, for several years we always went with a width ways orientation so we had a zero degress turning radius. but this last year we had a 4 wheel 2 spd tank that was long ways so to solve the manuverablility problem we implemented a pop-castor design that used a piston to push up the fron and turn on 2 castors and the rear wheels. It looks pretty sweet too!!!
It's Game Time
2006 to do list
Ship Robot- Mission Accomplished
Chesepeake regional-Engineering Inspiration
Philly Regional- Sportsmanship award
Nationals in Atlanta- 4th in GALI...LEO, Sportsmanship award
thanks to 86 and 190 for an awesome run in GA
  #36   Spotlight this post!
Unread 30-10-2006, 18:44
foote stepped in
AKA: E. Foote
FRC #0868
the vector math is easier, and actually is just converting joy input to PWM values (4 lines of code)...
In a stroke of brilliance one of our programmers got rid of all the vectors... and explained "To go left, turn these wheels forward, those ones backward. To go right, turn these wheels backward, those ones forward. To go forward, all wheels go forward, backwards the same. To spin, turn these 2 forward, these 2 backward, and vice-versa" (as he pointed to our diagram).
now (like all other drives) the driver is thinking in terms of the robot, so they're the ones "doing the math".
The robot isn't remembering where it is, so theres fewer vectors involved.
If the robot did remember where it was, the coding would become absolutely atrocious.
  #37   Spotlight this post!
Unread 30-10-2006, 19:19
...We also found out that a gyro is affected by temperature, pressure, etc. greatly; and that it gave out different readings at different times of the day ...
if that was true then your gyro was defective or there was a bug in your code reading the gryo value. Solid state gyros are highly reliable, the same AD chips used on the robots are used in cars for things like airbags and stability control (steering).
One thing about the gyros, they must be solidly mounted to the chassis of the robot. If the gyro can wiggle and vibrate (if you hold it down with tie wraps, or foam tape) you will get all sorts junk on the output signal.
To be useful the gyro chip must move exactly the same as the robot chassis moves.
  #38   Spotlight this post!
Unread 20-11-2006, 21:09
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
Our 2006 Martian robots were initially designed and built with the same knobby pneumatic skid steer drive train layout we had in 2003,4, and 5. This proved to be too unstable during turning because of the robots’ higher center of gravity. The diagonally placed omni wheels were installed very late in the build. Omni wheels are fine for maneuverability, but not good for resisting a lateral push.
If we had it to do over again, we would have had a drive train very similar to what 469 did this year (and what we did in 2001 on our first Martian robot). Las Gorillas had a skid steer with a set of deployable ball casters on the front right and left to lift the front of the robot off of the ground for maneuverability. When the casters were retracted, all four knobby pneumatic tires were on the ground for impressive pushing power and sideways stability against an aggressor.
  #39   Spotlight this post!
Unread 22-11-2006, 15:21
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Originally Posted by Pavan
Team 118 used a crab drive, drive train. ...
What are the joystick controls you use? I can see that the robot can slew around very easily, but what if you really do want to face the robot to a different heading?
  #40   Spotlight this post!
Unread 22-11-2006, 15:36
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
When HOT did crab in 2005, we used a regular black Flightstick (forward, backward, left strafe, right strafe) and a Playstation steering wheel to change the robot's orientation.
We just opened up the case of the steering wheel and soldered some wires onto the potentiometer to put into a gameport connector.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
  #41   Spotlight this post!
Unread 22-11-2006, 15:51
PandaMan's Avatar
PandaMan PandaMan is offline
I Am Bharat Nain
AKA: Aditya Pandyaram
FRC #0025 (Raider Robotics)
PandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond reputePandaMan has a reputation beyond repute
Send a message via AIM to PandaMan
Although swerve drive can maneuver around objects, it is not the most physical of drive trains. From what I've seen, the most effective drive seems to be the 6WD.
Team 25: Raider Robotix
Championship Winner: [2000]
Divisional Winner: Archimedes [2002], Curie [2003], Newton [2006]
2006 NJ Regional Winner, LV Regional Winner, Newton Division Winner, CMP Finalist
2006 Record: 45-5-0
2007 NJ Regional Winner, UTC Regional Finalist
2007 Record: 32-8-2
2008 NJ Regional Winner
2008 Record: 27-12-1
2009 NJ Regional Finalist
2009 Record: 26-12-3
2010 NJ Regional Winner, LV Regional Winner
2010 Record: 31-1-0
  #42   Spotlight this post!
Unread 22-11-2006, 18:03
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
MORT's best drive train was a 4-wheel.
It used 5" (I think, I'm sure Brandon can correct me) Colson wheels with a very short, wide wheelbase (long robot, short wheelbase) to cut down on scrub. The tipping problems of a short wheelbase were solved with 4 ball casters, one on each corner. It handled beautifully, could get up some decent speed, and was a pretty vicious defender. (I'm pretty sure that robot provoked the no-wedge rule.) Keep in mind however, that this was a flatland drive train for triple-play.
General suggestions based on that bot:
*Colsons rock
*Find the happy balance in the ratio or use a 2speed tranny. (I don't remember what our ratio was.)
*Short, wide wheelbase reduces scrub.
*Ball casters are beautiful on flat land.
*Keep the game in mind. A flat game needs no clearance, a ramp does.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
  #43   Spotlight this post!
Unread 22-11-2006, 23:14
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Just an off topic post. If you want manuverable go with a wide robot. Doesn't matter how many wheels you have, it will still be better than a long robot.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
  #44   Spotlight this post!
Unread 22-11-2006, 23:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
All other things being equal, a typical six wheel drive along the long axis will have a shorter effective wheelbase than a four wheel drive arranged on the short axis.
--Madison--
...down at the Ozdust!
  #45   Spotlight this post!
Unread 23-11-2006, 03:01
Joel J's Avatar
Joel J Joel J is offline
do you..
Is there a way to calculate the force (or torque, whatever) required to have a robot turn?
Joel Johnson
RAGE (173) Alumni, 1999-2003
what type of shooter will be most common this year? gondorf Technical Discussion 16 16-01-2006 17:05
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
What will be the most effective robot type this year Rick General Forum 8 13-01-2002 22:10
