Go to Post This isn't just a robot competition, it's not robots driving robots. It's people driving robots, and teams of people who have put a lot into making the robots work. - Gadget470 [more]
Unread 30-10-2006, 22:37
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
So, How do you shift?
Alright folks, I have a question for y'all. How do you shift gears at the operator station?
Do you use the buttons on the joystick? Do you use a switch on the control board? Do you use a switch that was custom mounted on the joystick? Or do you use something totally different?
Any and all comments are appreciated.
/dan
Unread 30-10-2006, 22:43
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: So, How do you shift?
Right trigger controls shifting. Left trigger switches between single and dual joystick control. Left top button rotates though the joystick translation profiles.
Right top button controls the ejection seat.
Unread 30-10-2006, 22:54
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Right Trigger to shift.
Originally it was left trigger, but right was better for me and left the left trigger for something else.
Unread 30-10-2006, 22:55
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
i get in my seat, get comfy, buckle up for saftey ( i recommend it to everyone) put the key in the ignition, and as with every thing i have ever driven, i use the automatic transmission stick that is on my steering column, and shift into forward or reverse as needed, there is even an option for 2nd or 1st gear, but i really never use those
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 30-10-2006, 23:02
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
r thumb trigger
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 30-10-2006, 23:07
AdamHeard's Avatar
Lead Mentor
Team 294 will be using either a 2 or 4 speed transmission this year that will be controlled by encoders.
We are planning on using the triggers as manual overrides.
If we have the 4 speed, we will automatically switch between 2 and 3 as the standard speeds and use the triggers to force it into high and low gear. But, this all depends on the game; We may cancel our plans for shifters if we don't need them.
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We use an on/off switch on the handle of the joystick. We cut a square hole in the grip portion (where your palm would normally go) so our driver never has to remove his hand from the prefered position he holds it at (which is towards the base of the joystick, resting his palm on the base at times). The reason we (I) prefer the on/off switch is that you can always look down and know what gear you are in. We had thought about using the trigger or a momentary button, but we could never be sure what gear we were in. Granted, you should know... unfortunately, however, in the heat of competition you never really can be sure of anything.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 30-10-2006, 23:47
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
ofcorse you could have some leds to show what gear your in......heck you could make a HUD (heads up display for them......put them on the brom of a hat so you could see the or something......
Unread 31-10-2006, 00:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
joystick trigger.
2001-2004: Team 100
2006-Present: Team 254
Unread 31-10-2006, 00:42
Jeff K.'s Avatar
Hmm..now what?
It could tell you that you have powered the solenoid to shift, but it doesn't tell you if it actually shifted or not. We installed reed sensors for this in case to see if we actually completed the shift or not. We ordered the magnetic piston, and installed two on each cylinder to know when it completed the shift. When we lowered the psi to the shifters, it shifted flawlessly, so we didn't need the sensors.
Also, I'm not sure about you, but I'm not a hat person.
Unread 31-10-2006, 10:48
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
The Jeep Bot used the forward/reverse lever of the power wheels car to shift to first or second .
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 31-10-2006, 12:45
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
we have an automatic or manual 4 speed. I believe we took the idea from team 33 killer bees. We use encoders to tell our pistons when to fire. this way we can determine the best shift points. Just in case the encoders go out we can switch to manual and we use 1 of the top buttons on the right to go up and one on the left to go down. We can also use either trigger to drop into 1st gear for pushing(or staying stationary better) or by pushing both triggers it goes into 1st gear and shuts off the compressor to give a little added power.
2005-2008: Student Mechanical and Strategy Lead
2009-2010: Mechanical Mentor
2011-2013: Strategy and Field Team Mentor
Unread 31-10-2006, 13:01
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
On our interface last year we had three arcade style buttons labeled "Light Speed", "Ridiculous Speed", and "Ludicrous Speed". After our transmissions fried we didn't use them too much anymore.
EDIT: pic of our OI at nationals:
Unread 31-10-2006, 13:09
Mechanical parts can fry?
We've always just used the triggers. When we had the 4 speed (waste of time), we had the indicator LEDs light up on the OI to show what gear we were in.
Unread 31-10-2006, 13:19
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
On Team 340, we use the black joysticks. On these, there are two buttons per joystick. They are located on the top, and the other one is a trigger. We only use one joystick for the shifting, generally the right one.
How do you shift?? Mike Nawrot Technical Discussion 3 24-02-2006 18:54
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
