Dear fellow robotics competitors and/or OCCRA staff,
ok. so the JAMD robotics team is currently trying to devise a pneumatic system to lift the basket. we need the EXACT measurement (as close as possible) of the height of the bottom of the metal bar relative to the ground, the EXACT measurement (again, as close as possible) of the bar's diameter, and also the EXACT distance (...once again...) of the distance from the side of the metal bar to the side of the box. Much Appreciated, The "Varsity" JAMD Robotics Team ![]() Last edited by jamd : 31-10-2006 at 11:55. Reason: Other stuff we need... |
Re: Moving the basket... HELP!!
I believe the bottom of the bar is about 27.5 inches above the ground. It has a 3/4 inch diameter. As for the last dimension, I assume you are talking about how far out from the basket the handle extends? if this is correct, then the dimension should be about 11 inches.
Run a search for the cad drawings; Im not sure where they are, but thats where all this info came from. good luck |
I second that one, it sounds right. ![]() |
| [OCCRA]: Basket? | ZOMGLASERGUNS | OCCRA | 1 | 27-09-2006 18:41 |
| pic: 1251 moving up in the world | Billfred | Extra Discussion | 2 | 25-04-2006 18:11 |
| [OCCRA]: what time is the occra banquet? | MatthewArthur | OCCRA | 3 | 01-12-2005 17:28 |
| [OCCRA]: After the first OCCRA competition | ah27 | OCCRA | 7 | 27-10-2004 22:16 |
| Moving the Nats. Date? | roboTICKS-236 | General Forum | 4 | 19-03-2003 22:49 |
